Debugging externally built projects [message #38757] |
Tue, 20 July 2004 13:09  |
I would like to use AJDT 1.1.11 to debug an AspectJ application that I
build with an ant script rather than with the eclipse builder. If I try
to do this, I can't set any breakpoints. When I try to set one, I get an
error from AJDT that I am missing structure information. Does AJDT enable
some secret compiler option to get this structure information? I would
like to know if it is possible to work in this way.
-Jeff
Re: Debugging externally built projects [message #38888 is a reply to message #38826] |
Wed, 21 July 2004 09:46  |
Luzius Meisser wrote:
> is missing. As a consequence, you will be able to set breakpoints at
> unreasonable lines (e.g. inside comments) as long as the project has not
> been compiled with AJDT.
> This will be included in the next AJDT release.
Thanks! I think this is a good trade-off and is similar to what happens
with a plain Java program built outside Eclips.
-Jeff
Re: Debugging externally built projects [message #581785 is a reply to message #38757] |
Wed, 21 July 2004 05:47  |
Hi Jeff,
The structure model was only used to check if the breakpoint was set on a
valid line. I did not think about your use case when I wrote this check so I
changed the behaviour now to set the breakpoint even if the structure model
regards,
Luzius
"Jeff Loomis" <jloomis@authentica.com> wrote in message
news:cdjjk0$2g9$1@eclipse.org...
> -Jeff
Re: Debugging externally built projects [message #581836 is a reply to message #38826] |
-Jeff
FUDForum. Page generated in 0.08370 seconds
