Home » Modeling » Epsilon » Explicit invocation of ETL rule
Explicit invocation of ETL rule [message #490312] |
Thu, 08 October 2009 06:41  |
Originally posted by: c.k.holmes.lboro.ac.uk
Dear All,
I have two transformation rules of the form:
rule LogAttributesType2LogAttributesSwitchType
transform logAtts1 : Source!LOGATTRIBUTESType
to switchType : Target!LogAttributesSwitchType {
guard : logAtts1.type = Source!LogAttType#CODE and
logAtts1.codeType = Source!CodeType#SWITCH
'LogAttributesType2LogAttributesSwitchType'.println();
--<blah/>
switchType.switchValues := logAtts1.cODEVAL.collect(v |
v.transformCodeVal2SwitchVal());
rule LogAttributesType2LogAttributesEnumType
to enumType : Target!LogAttributesEnumType {
logAtts1.codeType = Source!CodeType#ENUM
'LogAttributesType2LogAttributesEnumType'.println();
--<blah/>
enumType.enumeratedValues := logAtts1.cODEVAL.collect(v |
v.transformCodeVal2EnumVal());
The 'cODEVAL' attribute on the source class is the same in both cases,
however I want to apply different transformation rules to this attribute
depending of which transformation is currently being invoked.
I have defined the two transformation operations as:
operation Source!CODEVALType transformCodeVal2EnumVal() : Target!EnumVal {
var result : Target!EnumVal;
'transformCodeVal2EnumVal'.println();
(self.eClass().name).println();
result.value := self.value;
result.meaning := self.meaning;
return result;
operation Source!CODEVALType transformCodeVal2SwitchVal() :
Target!SwitchVal {
var result : Target!SwitchVal;
'transformCodeVal2SwitchVal'.println();
return result;
The execution trace shows the following error message:
transformCodeType2LogAttCodeType
CODEVALType
EXCEPTION: Called feature value on undefined object
(C:\EclipseWorkspaces\Blah\MyTransformation.etl@lineNo)
The appropriate transformation operation has been invoked
(transformCodeVal2EnumVal), and self is of the expected type
(CODEVALType), however it appears to suggest that the receiver (self) is
undefined when I try to access one of the attributes.
Using the following 'generic' transformation runs without throwing an
error (although it doesn't provide me with the flexibility of specifying
when to return an EnumVal object and when to return a SwitchVal object):
rule CodeVal2EnumVal
transform cv1 : Source!CODEVALType
to ev2 : Target!EnumVal {
ev2.value := cv1.value;
ev2.meaning := cv1.meaning;
So I guess I have two questions:
1. Why does self.eClass().name return the expected type (CODEVALType),
and yet on the very next line when I try to access self.value does self
appear to be undefined?
2. Is there an easier way to achieve the explicit invocation of one rule
from another?
Best Wishes
Chris
Re: Explicit invocation of ETL rule [message #490386 is a reply to message #490371] |
Thu, 08 October 2009 09:58   |
Hi Dimitris,
Thanks for identifying my error - I'm somewhat embarrassed that I didn't
spot it myself :(
It would be useful to be able to invoke a rule by name, in this instance
at least, rather than relying on the equivalent() operation to do the
type match.
Thanks once again.
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Please see comments below:
> Chris Holmes wrote:
>> Dear All,
>> --<blah/>
>> --<blah/>
>> attribute depending of which transformation is currently being invoked.
>> Target!EnumVal {
>> return result;
>> Target!SwitchVal {
>> return result;
>> CODEVALType
> This happens because result (rather than self) is null in both
> operations. To initialize it you need to replace
> with
> var result : new Target!EnumVal;
> (and similarly for the second operation)
>> is undefined when I try to access one of the attributes.
>> specifying when to return an EnumVal object and when to return a
>> SwitchVal object):
>> self appear to be undefined?
>> rule from another?
> The .equivalent() operation explicitly calls all the rules applicable to
> the source. Would you like to be able to invoke only a specific named
> rule instead?
>> Best Wishes
>> Chris
> Cheers,
> Dimitris
Re: Explicit invocation of ETL rule [message #490387 is a reply to message #490386] |
Thu, 08 October 2009 10:01  |
Hi Chris,
Chris Holmes wrote:
> Hi Dimitris,
> spot it myself :(
No worries. It took me a while to figure this out too - mainly because I
was looking at the wrong place...
> type match.
Could you please file an enhancement request in the bugzilla?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
> Thanks once again.
You're welcome!
> Best Wishes
> Chris
Dimitris
>> Hi Chris,
>> Chris Holmes wrote:
>>> Dear All,
>>> --<blah/>
>>> --<blah/>
>>> cases, however I want to apply different transformation rules to this
>>> Target!EnumVal {
>>> return result;
>>> Target!SwitchVal {
>>> return result;
>>> CODEVALType
>> with
>>> SwitchVal object):
>>> (CODEVALType), and yet on the very next line when I try to access
>>> self.value does self appear to be undefined?
>>> rule from another?
>> to the source. Would you like to be able to invoke only a specific
>> named rule instead?
>>> Best Wishes
>>> Chris
>> Cheers,
>> Dimitris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Explicit invocation of ETL rule [message #581684 is a reply to message #490312] |
Thu, 08 October 2009 09:26  |
Hi Chris,
Chris Holmes wrote:
> Dear All,
> --<blah/>
> --<blah/>
> return result;
> Target!SwitchVal {
> return result;
> CODEVALType
with
> from another?
rule instead?
> Best Wishes
> Chris
Dimitris
Re: Explicit invocation of ETL rule [message #581710 is a reply to message #490371] |
Hi Dimitris,
spot it myself :(
type match.
Thanks once again.
Best Wishes
Chris
> Hi Chris,
> Chris Holmes wrote:
>> Dear All,
>> --<blah/>
>> --<blah/>
>> Target!EnumVal {
>> return result;
>> Target!SwitchVal {
>> return result;
>> CODEVALType
> with
>> SwitchVal object):
>> rule from another?
> rule instead?
>> Best Wishes
>> Chris
> Cheers,
> Dimitris
Re: Explicit invocation of ETL rule [message #581727 is a reply to message #490386] |
Hi Chris,
Chris Holmes wrote:
> Hi Dimitris,
> spot it myself :(
> type match.
> Thanks once again.
You're welcome!
> Best Wishes
> Chris
Dimitris
>> Hi Chris,
>> Chris Holmes wrote:
>>> Dear All,
>>> --<blah/>
>>> --<blah/>
>>> Target!EnumVal {
>>> return result;
>>> Target!SwitchVal {
>>> return result;
>>> CODEVALType
>> with
>>> SwitchVal object):
>>> rule from another?
>> named rule instead?
>>> Best Wishes
>>> Chris
>> Cheers,
>> Dimitris
Current Time: Sun Jul 20 09:41:16 EDT 2025
Powered by FUDForum. Page generated in 0.08883 seconds
