Home » Eclipse Projects » Eclipse 4 » Confusion about Eclipse 4.0 Application Model
Confusion about Eclipse 4.0 Application Model [message #581330] Tue, 31 August 2010 02:44 Go to next message
I have a Plug-in Project defining a product with an e4 Application Model, and another Plug-in Project that extends the application by some menu items.
When defining commands and handlers in the fragment XMI, I have to specify a String Model Fragment with the feature name "commands" of the element id "<my application id>".
So defining commands/handlers within an e4 Model Fragment does always refer to a single application. So for the definition of common menu entries, I have to use extension points, is that correct?
And e4 Model Fragments within a plugin make the plugin dependent from launching a special product, right?
Hope I expressed the problem understandably.
Re: Confusion about Eclipse 4.0 Application Model [message #581440 is a reply to message #581330] Wed, 08 September 2010 08:22 Go to previous messageGo to next message
Extension points for command, etc aren't currently supported in pure e4
applications yet.
If you want re-usable fragments, you have to settle on an "id
convention", as they're simply be applied per-id.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Confusion about Eclipse 4.0 Application Model [message #581514 is a reply to message #581330] Thu, 09 September 2010 07:36 Go to previous message
You are right. Currently the contribution system expects you to know the
ID of the element but for 4.1 I plan to improve it in a way that you can
use XPath expressions one could then contribute to the
MApplication-Element through "/MApplication", ... .
In 4.0 you can use a Processor to generically identify the root element
to contribute a command and do much more fancy contributions (e.g. based
upon a user credential, ...).
If you are not sure how this looks like you can take a look at my
Live-ModelTooling integration which does exactly what you asking for here.
The source is available in:
e4/org.eclipse.e4.tools/bundles/org.eclipse.e4.tools.emf.liv eeditor and
the thing you are interested in is the:
* ModelProcessor
* plugin.xml
Tom
Am 31.08.10 08:44, schrieb Ralf Zahn:
> menu items.
Previous Topic:Workbench Save Restore
Next Topic:Reuse eclipse 3.x views
Current Time: Sat Jul 19 14:02:17 EDT 2025
Powered by FUDForum. Page generated in 0.04406 seconds
