Home » Eclipse Projects » DSDP - Target Management » RSEC1002
RSEC1002 [message #580956] Wed, 03 June 2009 15:22
I have the following
eclipse 3.4 GanyMede
RSE 3.0.3
Embedded Linux
2.6.22
JRE 1.4
I installed and have the daemon.pl and server.pl running. They don't
indicate any issues.
When i try to connect to the "shells" or "Processes" using DStore through
eclipse it gets the following errors.
RSEC1002
in SubSystemConfiguration.getSubSytems(conn, force) - returning empty array
No stack trace available.
Then I get a dialog box saying the following.
"Invalid password or user ID" clicking on the "<<Details" buttons shows
the following:
Authentication with 10.227.4.17 failed because the password or user ID is
not correct.
this is the correct ip address. I can connect using "Files" (ftp) and do
everything from there. it get the file system and can edit files.
But anything that uses the DStore gives me a username or password issue.
The username and password is good. I tried the user of "admin" and root
user "root" and both of them give me errors inside eclipse.
I see nothing on the embedded linux console that shows any kind of error.
Any help would be great!!!!
Thanks ahead of time.
Kevin
Previous Topic:RSE flat single level view, no directories
Next Topic:RSEC1002
Current Time: Sat Jul 19 12:43:06 EDT 2025
Powered by FUDForum. Page generated in 0.02922 seconds
