Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » emf validation and allInstances
emf validation and allInstances [message #37259] Mon, 12 June 2006 16:47 Go to next message
Originally posted by: saya.txesystems.com
Is there a way to use ocl allInstances() in the invariants that are
provided in through constraint provider extensions? I have tried
specifying an invariant like Address.allInstances()->asSet()->size()=3 in
the xml file (Address is an EClass) but, when I run batch validation on an
instance of Address, the satus says that this constraint was disabled
becuase of a NullPointerException. When I evaluate a ocl query on an
eObject, I can use query.setExtentMap(). Is there a way to do this with
the validation framework?
I would appreciate any pointer. We have some constraints on our metadata
that require us to know all instances of an EClass and we need a construct
like allInstances().
Selcuk
Re: emf validation and allInstances [message #37327 is a reply to message #37259] Tue, 13 June 2006 09:31 Go to previous message
Hi, Selcuk,
You are correct: the current implementation of Query will NPE on an attempt
to use allInstances() without setting the extent map, and the validation
framework does not provide a work-around.
This problem will be resolved incidentally by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=146378.
Christian
Selcuk Aya wrote:
> Selcuk
Re: emf validation and allInstances [message #580699 is a reply to message #37259] Tue, 13 June 2006 09:31 Go to previous message
Hi, Selcuk,
Christian
Selcuk Aya wrote:
> Selcuk
Previous Topic:emf validation and allInstances
Next Topic:newbee ocl standalone
Current Time: Sat Jul 19 11:05:17 EDT 2025
Powered by FUDForum. Page generated in 0.25266 seconds
