Home » Archived » AM3 » problem on installing new am3 (difficults in launching?)
problem on installing new am3 [message #542264] Thu, 24 June 2010 07:57 Go to next message
Hi everybody
I'm new in atl and also in am3.
I'm using Eclipse 3.4, emf-xsd-SDK-2.6.0M7 and m2m-atl-runtime-3.1.0.
I have trying runnig an UML2OWL example, but I got the problem of not recognizing the am3 tag's by running the build.
I got from the " http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Tools#ATL_a nt_tasks" that the tag's for atl 3.xx must be modified.
But my problem is in lunching am3. I have downloaded it from the SVN conforms to "http://wiki.eclipse.org/AM3/How_Install_New_AM3_From_SVN"
but I don't get how to execute am3 in Run-time workbench, and there are errors in the projects.
Is there any package of am3 binaries for just put it in the plugins and features eclipse's folder?
if yes, where? if not, how launching/execute am3 from source.
could you please help me?
Thank you very much for help!
Best wishes,
Júlio
Re: problem on installing new am3 [message #542349 is a reply to message #542264] Thu, 24 June 2010 11:16 Go to previous messageGo to next message
Hi Julio,
If you use ATL3.x, you have to use the "new" ATL ANT tasks as explained in the ATL user guide: http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Tools#ATL_a nt_tasks
If you want to use ATL2.x with the "old" ANT tasks, you have to get the required plugins by following the instructions from http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN
You can also get a ready-to-use bundle with ATL2.x from http://docatlanmod.emn.fr/Eclipse_Bundles/AMMA_Prototype/AMM APrototypeEclipse.zip
The manual for these "old" tasks is available from http://wiki.eclipse.org/AM3_Ant_Tasks
I hope this help.
Hugo
Re: problem on installing new am3 [message #542358 is a reply to message #542349] Thu, 24 June 2010 11:31 Go to previous messageGo to next message
Hi Hugo!
Thank you so much for your attention.
I'm using ATL3.x and actually using the ATL ANT tasks as explained in the ATL user guide that you have mentioned. The error as described before not happens anymore.
SO it means that I don't need to install am3?
I'm gonna use the OWL2XML.atl, an ATL transformation that transforms an OWL Model into an XML models with OWL/XML syntax elements.
I have heard it uses the XML extractor, so Do I need am3 for that?
if yes, I still will have the problem concerning to install the new am3 with ATL3.xx
Thank you so much
Júlio
Re: problem on installing new am3 [message #543847 is a reply to message #542349] Wed, 30 June 2010 14:33 Go to previous messageGo to next message
hi Júlio
can you please explain more your reply
ATL3.x am3 checkouts, where can I find them and what is the right link for SVS eclipse 3.5.2 to check them out.
please I wana download them as soon as possible
Hugo Bruneliere wrote on Thu, 24 June 2010 18:16
Hi Julio,
I hope this help.
Hugo
Re: problem on installing new am3 [message #544145 is a reply to message #543847] Thu, 01 July 2010 14:15 Go to previous messageGo to next message
sorry, I didn't understand your question...
please be more objective and clear
regards
Re: problem on installing new am3 [message #552888 is a reply to message #542349] Sat, 14 August 2010 00:31 Go to previous messageGo to next message
Hi Hugo,
I tried installing AM3 for my existing configuration of eclipse ( ATL 3) and it showed wierd error so I left the installing for now.
I downloaded the preconfigured eclipse from the link that you provided.
When I switch to AM3 presepctive, it reports me an error.
Could not create the view: Plug-in "org.eclipse.am3.ui" was unable to instantiate class "org.eclipse.am3.ui.view.ResourceNavigatorAM3".
I dont have any clue abt this error.
Could you please help me out?
Re: problem on installing new am3 [message #552950 is a reply to message #552888] Sun, 15 August 2010 00:29 Go to previous messageGo to next message
Hello all,
I downloaded the version specified by Hugos for ATL 2.X and started working in AM3. Smile
Please discard this message.
[Updated on: Sun, 15 August 2010 00:30] by Moderator
Re: problem on installing new am3 [message #579981 is a reply to message #542264] Thu, 24 June 2010 11:16 Go to previous messageGo to next message
Hi Julio,
I hope this help.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN)
Ecole des Mines de Nantes
Nantes - France
Re: problem on installing new am3 [message #580077 is a reply to message #579981] Wed, 30 June 2010 14:33 Go to previous messageGo to next message
hi Júlio
> Hi Julio,
> I hope this help.
> Best regards,
> Hugo
Re: problem on installing new am3 [message #580096 is a reply to message #580077] Thu, 01 July 2010 14:15 Go to previous messageGo to next message
regards
Re: problem on installing new am3 [message #580147 is a reply to message #579981] Sat, 14 August 2010 00:32 Go to previous messageGo to next message
Hi Hugo,
Re: problem on installing new am3 [message #580164 is a reply to message #580147] Sun, 15 August 2010 00:30 Go to previous message
Hello all,
I managed to solve this.
Previous Topic:[KM3] Problems with meta-model extension
Next Topic:Interesting problem
Current Time: Sat Jul 19 17:22:27 EDT 2025
Powered by FUDForum. Page generated in 0.05291 seconds
