Home » Eclipse Projects » Plugin Development Environment (PDE) » Help plugin functions in 3.3, but not in 3.4
Help plugin functions in 3.3, but not in 3.4 [message #20444] Wed, 10 September 2008 11:30 Go to next message
I'm hoping this is the right group, please tell me if not!
I need to intergrate a simple Help plugin into both Eclipse 3.3 and 3.4.
My test plugin functions correctly in version 3.3, but does not show up
in version 3.4.
Has something changed between the two versions?
Thanks.
James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #21051 is a reply to message #20444] Wed, 10 September 2008 16:43 Go to previous messageGo to next message
Originally posted by: nospam_kowalskilee.gmail.com
Hi James,
The best newsgroup would be eclipse.platform.ua. I'm adding that
newsgroup to this thread.
Can you describe more about how you are adding the help plug-in to
Eclipse 3.3 and 3.4?
Yes, things have changed between the two versions. In Eclipse 3.4, the
method for providing plug-ins has changed. You can't simply add a new
plug-in to the plugins directory any more. There is a "dropins"
directory into which you can drop plug-ins. Sometimes you have to use
the -clean parameter on startup to ensure that Eclipse recognizes to
check the dropins directory.
Did you create your help plug-in with PDE or some other tool?
Lee Anne
> in version 3.4.
> Thanks.
> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #21197 is a reply to message #21051] Fri, 12 September 2008 00:22 Go to previous messageGo to next message
I'm facing a similar issue, I'm packaging the help in a 3.4 based
product, and my help plugin does not seem to contribute to the help at all.
Did you get to resolve this issue ?
-- Ketan
Lee Anne wrote:
> Hi James,
> Best regards,
> Lee Anne
>> 3.4. My test plugin functions correctly in version 3.3, but does not
>> show up in version 3.4.
>> Thanks.
>> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #21276 is a reply to message #21197] Fri, 12 September 2008 11:12 Go to previous messageGo to next message
Hi Ketan
How did you create your help plug-in? Using PDE or another tool?
Does it have a MANIFEST.MF file?
How are you adding in the help plug-in? Are you putting it into the
plugins directory or the dropins directory or exporting it using the PDE?
In general, I have seen comments from people stating that they have
dropped plug-ins into dropins and sometimes they are picked up, and
sometimes they aren't and then 'magically' they are. For example, see
this eclipse.platform thread from July:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 369.html
Ed Merks wrote:
"Yes, I ran into a weird problem where I changed the version of a plugin
from 2.4.0 to 2.4.1 and it caused the plugins to fail to resolve for
mysterious reasons and my efforts to clear the configuration made a
mess; eclipse would start, but Java projects weren't recognized as Java
projects anymore. I'm not sure what the proper way to force a clean
revisiting of all the dependencies. I've heard someone say -clean does
nothing for p2, but that might just be an ugly rumor. "
You could try using the -debug flag to get more details about what
Eclipse is doing as it is starting.
I haven't done any more iterative tests since my last posting. I did get
a help plug-in to appear when I removed the version portion of the
plug-in's directory (so that it was like com.blah.doc and not
com.blah.doc_1.0.9). But I could not get a repeatable experiment yet to
submit a bug or pinpoint the behavior.
Hope this helps,
Lee Anne
> -- Ketan
Re: Help plugin functions in 3.3, but not in 3.4 [message #22202 is a reply to message #21276] Mon, 15 September 2008 14:27 Go to previous message
Lee Anne wrote:
> Hi Ketan
We're building an RCP app, and all stuff lives in plugins, we used the
standard pde templates to create the plugin, and later customized it to
our needs (all of the help and TOC is auto generated out of XML)
The manifest looks like:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Twist Help Plug-in
Bundle-SymbolicName: com.thoughtworks.twist.help; singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Vendor: http://thoughtworks.com/twist
Bundle-RequiredExecutionEnvironment: J2SE-1.5
The plugin.xml looks like:
<?eclipse version="3.2"?>
<plugin>
<extension point="org.eclipse.help.toc">
<toc file="toc.xml" primary="true />
</extension>
</plugin>
-- Ketan
Re: Help plugin functions in 3.3, but not in 3.4 [message #579716 is a reply to message #20444] Wed, 10 September 2008 16:43 Go to previous message
Hi James,
Lee Anne
> in version 3.4.
> Thanks.
> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #579913 is a reply to message #21051] Fri, 12 September 2008 00:22 Go to previous message
-- Ketan
Lee Anne wrote:
> Hi James,
> Best regards,
> Lee Anne
>> Thanks.
>> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #580009 is a reply to message #21197] Fri, 12 September 2008 11:12 Go to previous message
Hi Ketan
Hope this helps,
Lee Anne
> -- Ketan
Re: Help plugin functions in 3.3, but not in 3.4 [message #580462 is a reply to message #21276] Mon, 15 September 2008 14:27 Go to previous message
Lee Anne wrote:
> Hi Ketan
<plugin>
</extension>
</plugin>
-- Ketan
Previous Topic:p2'izing an application takes too long
Next Topic:PDE Build failure: OutOfMemoryError: Java heap space
Current Time: Sun Jul 20 10:31:11 EDT 2025
Powered by FUDForum. Page generated in 0.04499 seconds
