Problems with HelloWorld example with eclipse 3.0M8 [message #35516] |
Mon, 10 May 2004 10:40  |
Originally posted by: Michael-Scharf.gmx.de
I am trying AJDT with eclipse 3.0M8. I followed the tutorial and
I have problems with the HelloWorld example.
- aspectj compiler version 1.2rc1
- aspectj plugin version 0.6.8
When I create the aspect "World.aj" or "World.java" I get the following problems:
01 public class World {
02 pointcut greeting(): execution(* HelloWorld.sayHello(..));
03 after() : greeting() {
04 System.out.println("Hello to you too...")
05 }
06 }
Syntax error on token ";", invalid PseudoToken World.java aspectj line 2
Syntax error, insert ";" to complete ClassBodyDeclarations World.java aspectj line 3
Syntax error, insert ";" to complete BlockStatements World.java aspectj line 3
I use the aspectj editor. The syntax highlight highlights the aspectj keywords
correctly.
Any help or hints on what I am doing wrong?
Michael
Re: Problems with HelloWorld example with eclipse 3.0M8 [message #35616 is a reply to message #35548] |
Thu, 13 May 2004 03:32  |
Originally posted by: clemas.uk.ibm.com
Hi Michael,
Just a quick word of warning - that might not have been your fault!!
1.1.8 does offer some code assist but the mechanism is a bit shaky. When
you press Ctrl+Space whilst in an aspect, we transform the word 'aspect'
to 'class ' and ask the normal JDT code to work out possible completions.
When it has worked them out, we switch it back from 'class ' to 'aspect'.
Sometimes switching it back doesn't quite work (I dont know why) and it
stays as 'class '. The reason it looks like this is what happened in your
case:
is that you have an extra space between class and World which is just how
it looks if the switch back to 'aspect' doesn't work !
Andy.
AJDT Dev.
Re: Problems with HelloWorld example with eclipse 3.0M8 [message #579455 is a reply to message #35516] |
Mon, 10 May 2004 13:55  |
I found the problem :-D, my fault!
I wrote "class" instead of "aspect"
> Hello,
> problems:
This is the real problem: i wrote "class"instead of "aspect"...
> 05 }
> 06 }
> aspectj line 2
> aspectj line 3
> keywords
> correctly.
> Michael
Re: Problems with HelloWorld example with eclipse 3.0M8 [message #579525 is a reply to message #35548] |
Hi Michael,
case:
Andy.
AJDT Dev.
FUDForum. Page generated in 0.24068 seconds
