Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » JET 1.0.0: incomplete xpath expressions?
JET 1.0.0: incomplete xpath expressions? [message #34483] |
Fri, 19 May 2006 12:10  |
I tried to use JET to parse, and generate files from a uml model, but I
encountered several problems:
1) JET can't recognize namespaces (or I don't know how to)
2) Xpath axes (ex: child::mytag) or some xpath syntax (ex: root//mytag)
are not supported.
Could someone tell me how I could do those please?
Re: JET 1.0.0: incomplete xpath expressions? [message #34655 is a reply to message #34483] |
Tue, 23 May 2006 09:54   |
Yannick:
I have successfully extracted information from a UML model (created with UML
2.0.0RC4). But you probably require more information than is currently in
the documentation.
JET has implemented a nearly complete subset of the XPath 1.0 specification.
The interesting thing about the JET implementation is that it is not limited
to just XML documents. There are interfaces that allow adapting XPath
expressions to any data model that has a spanning subtree.
Things that are missing from the JET implementation are:
* full namespace support
* the implementation of one XPath function: id()
* the implementation of some of the XPath axes
See details below:
1) namespace recognition is not complete - there is no way to map a prefix
in an XPath expression to an namespace URI. Alternatives:
* Use the local-name() XPath function to test only the local name - this
will essentially ignore the namespace.
Example: foo/*[local-name() = 'bar']
* Use the name() XPath function to test against the QNames - this
requires you to know the prefix in the document you are using.
Example: foo/*[name() = 'prfx:bar']
Namespace support will not be completed for 1.0. But, I don't think you
need it to parse a UML document. See below.
2) Only the following XPath axis are implemented: child, parent, self and
attribute (and their abbreviations). If other axes are important (I noticed
you used //, which is equivalent using the descendent-or-self axis), please
submit a bugzilla:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT& ;version=1.0&component=JET&rep_platform=PC&op_sy s=Windows%20XP&priority=P3&bug_severity=normal&b ug_status=NEW&assigned_to=pelder%40ca.ibm.com&qa_con tact=&cc=&bug_file_loc=http%3A%2F%2F&short_desc= &comment=&commentprivacy=0&keywords=&depends on=&blocked=&maketemplate=Remember%20values%20as%20b ookmarkable%20template&form_name=enter_bug
(sorry for the long URL, but it fills in most of the required fields for
you).
3) The JET XPath engine adapts to any EMF-based model (including UML2), as
follows:
* '/' refers to the document root (which, if you are familiar with the
EMF API's, is the EMF Resource)
* There is a special child of the document root implemented named
'contents' (which mirrors Resource.getContents()).
* If you have an XPath expression matching a subclass of EObject, then:
EReference features correspond to XPath child elements
EAttribute features correspond to XPath attribute
Example: If you have a typical UML model with a root object of type
Model, here are a number of XPath expressions you can use:
/contents - matches the root Model element
/contents/@name - returns the name of the Model element
/contents/nestedPackage - returns the packages contained
directly by the model
As a bonus, and because the UML meta-model in particular is so large and
most people don't know the feature names used for navigating the model, the
XPath engine will also recognize an eClass name when searching an element
axis. The best way to understand this is some more examples:
/Model - matches an EObject of type Model contained directly
by the root Resource
/Model/Package matches all EObjects of type Package contained
by the root Model object.
Paul Elder
JET2 Lead
"Yannick" <yannick@anyware-tech.com> wrote in message
news:e4kqls$5p4$1@utils.eclipse.org...
> are not supported.
Re: JET 1.0.0: incomplete xpath expressions? [message #35326 is a reply to message #34655] |
Fri, 26 May 2006 04:15   |
Thanks a lot for your reply, Paul.
I'll take my time to fully understand all you wrote. (It would also be
nice if your explanations could be in the documentation ;) )
Paul Elder a écrit :
> Yannick:
> the documentation.
> See details below:
> submit a bugzilla:
> you).
> follows:
> Paul Elder
> JET2 Lead
Re: JET 1.0.0: incomplete xpath expressions? [message #35427 is a reply to message #35326] |
Fri, 26 May 2006 08:29  |
Yannick:
I'm working (slowly) on the documentation. This week's integration build
includes some getting started material. Next week, there should be more
reference material, too.
Also, this week's integration build includes an implementation of the
'descendent-or-self' axis.
Paul
news:e56dfq$cr3$1@utils.eclipse.org...
> Paul Elder a
Re: JET 1.0.0: incomplete xpath expressions? [message #578329 is a reply to message #34483] |
Yannick:
the documentation.
See details below:
submit a bugzilla:
you).
follows:
Paul Elder
JET2 Lead
> are not supported.
Re: JET 1.0.0: incomplete xpath expressions? [message #578993 is a reply to message #34655] |
> Yannick:
> the documentation.
> See details below:
> submit a bugzilla:
> you).
> follows:
> Paul Elder
> JET2 Lead
Re: JET 1.0.0: incomplete xpath expressions? [message #579068 is a reply to message #35326] |
Yannick:
Paul
> Paul Elder a
Current Time: Sat Jul 19 23:18:31 EDT 2025
Powered by FUDForum. Page generated in 0.09572 seconds
