Home » Archived » Voicetools » Re: Programming by voice
Re: Programming by voice [message #578900] |
Thu, 07 January 2010 16:11  |
You should probably familiarize yourself with the Voice Tools Project
(http://www.eclipse.org/vtp/) - I don't think it really covers the area
that you're talking about, but it might be something that you can
leverage in an implementation of your idea. I'm not sure how active or
dormant that project is, however.
I've copied the VTP forum group on this reply
(http://www.eclipse.org/forums/eclipse.technology.voicetools)
Hope this helps,
Eric
On 1/7/10 1:41 AM, Frank Sem-Jacobsen wrote:
> I am currently deciding whether it is worth my while to create a
> project, probably within the research institution where I work, to
> create a efficient toolkit for programming by voice.
> My main idea is some tight integration with an IDE like eclipse to take
> care of formatting and navigating around projects, and also a voice
> syntax and grammar to write the actual lines of code. Examples of the
> former may be "add public integer X to class coordinates" which would,
> regardless of the current position of the cursor, add the correct
> variable to the correct class and return to the original position of the
> cursor. Much of the tedious navigation and formatting can be fixed this
> way.
> Regarding syntax and grammar, in order for this to work with multiple
> programming languages, one would have to to identify common programming
> constructs and create a comprehensive and uniform way of dictating this.
> Does anyone know whether such projects are underways anywhere, and how
> much interest would there be for such a project? I have found a
> reference to an editor called VASDE which was based on Eclipse around
> 2006. I have not found any references to this in Google.
> If it appears that no one is doing anything similar, and we agree that
> the approach is feasible, then I would like to try to arrange it. I know
> that some of you have tried this before with the old voicecode project,
> but I guess it is fair to say that that is pretty dead now.
> I have just started the process of figuring out from where I may get
> funding for such a project, and thinking that we need at least one guy
> for a year working 100% on this in order to get anything implemented at
> all. I think that the Eclipse integration should be quite
> straightforward (relatively speaking), and the most time would be spent
> on trying to create the language constructs to support it.
> This is a bit of what I'm thinking now, and I would greatly appreciate
> any feedback/ideas/comments you might have on the subject. Especially if
> could be useful to get in contact with those of you who have tried this
> before.
> Best regards,
> Frank Olaf Sem-Jacobsen, Ph.D. Postdoctoral Fellow Simula Research
> Laboratory
Re: Programming by voice [message #578910 is a reply to message #578900] |
Fri, 08 January 2010 12:54  |
Hi Frank and Eric--
The VTP project is not at all dormat, though the newsgroup doesn't see a
lot of action. I'm not sure how useful the VTP project would be in this
situation, but there might be a few bits of the project that would be
useful, particularly around the VXML construction.
Frank, good luck with your project -- sounds interesting. Let us know
if you think we might be able to help.
Randy Childers
OpenMethods
> area that you're talking about, but it might be something that you
> can leverage in an implementation of your idea. I'm not sure how
> active or dormant that project is, however.
> Hope this helps,
> Eric
>> Hi,
>> take care of formatting and navigating around projects, and also a
>> voice syntax and grammar to write the actual lines of code. Examples
>> of the former may be "add public integer X to class coordinates"
>> which would, regardless of the current position of the cursor, add
>> the correct variable to the correct class and return to the original
>> position of the cursor. Much of the tedious navigation and formatting
>> can be fixed this way.
>> programming constructs and create a comprehensive and uniform way of
>> dictating this.
>> how much interest would there be for such a project? I have found a
>> that the approach is feasible, then I would like to try to arrange it.
>> I know that some of you have tried this before with the old voicecode
>> project, but I guess it is fair to say that that is pretty dead now.
>> guy for a year working 100% on this in order to get anything
>> implemented at all. I think that the Eclipse integration should be
>> quite straightforward (relatively speaking), and the most time would
>> be spent on trying to create the language constructs to support it.
>> appreciate any feedback/ideas/comments you might have on the subject.
>> Especially if could be useful to get in contact with those of you who
>> have tried this before.
>> Best regards,
>> Laboratory
Current Time: Sun Jul 20 11:58:54 EDT 2025
Powered by FUDForum. Page generated in 0.03859 seconds
