Home » Eclipse Projects » Eclipse 4 » e4 RC0, moved IEclipseContext where?
e4 RC0, moved IEclipseContext where? [message #542546] Fri, 25 June 2010 05:58 Go to next message
Just updated to RC0 to find that org.eclipse.e4.core.services.context no longer exists. So started looking for the Javadoc to support e4 RC0, where is it? Also no release notes that I could find. Then googled to try to find a IRC or mailing list that mentions this change, no joy.
So the org.eclipse.e4.demo.contacts no longer works due to missing classes due to the change to the package structure. So where do I find out what it is?
David
Re: e4 RC0, moved IEclipseContext where? [message #542556 is a reply to message #542546] Fri, 25 June 2010 06:32 Go to previous messageGo to next message
IEclipseContext is in org.eclipse.e4.core.contexts.
The contacts demo from HEAD works fine for me in RC0.
Don't know about Javadocs or release notes, sorry.
Re: e4 RC0, moved IEclipseContext where? [message #542622 is a reply to message #542556] Fri, 25 June 2010 09:22 Go to previous messageGo to next message
Sadly were I work does not allow me to connect to a public CVS. So some supporting documentation of the changes would make a big difference. Typically I would expect package changes to be mentioned in release notes, but I could not find any?
Thx.
David
Re: e4 RC0, moved IEclipseContext where? [message #542829 is a reply to message #542622] Sat, 26 June 2010 10:35 Go to previous messageGo to next message
Try using the official eclipse cvs proxy if you are behind a firewall/proxy:
http://wiki.eclipse.org/CVS_Howto
In short:
proxy.eclipse.org 80
or
pebbles.eclipse.org 443
For me, the second worked.
Re: e4 RC0, moved IEclipseContext where? [message #543059 is a reply to message #542622] Mon, 28 June 2010 05:54 Go to previous message
You can get it using the Smart HTTP Git frontend
http://dev.eclipse.org/git/index.html
(don't forget to switch to HTTP uris and set your proxy variable if you
need to)
Simon
Re: e4 RC0, moved IEclipseContext where? [message #578125 is a reply to message #542556] Fri, 25 June 2010 09:22 Go to previous message
Thx.
David
Re: e4 RC0, moved IEclipseContext where? [message #578136 is a reply to message #542622] Sat, 26 June 2010 10:35 Go to previous message
In short:
or
Re: e4 RC0, moved IEclipseContext where? [message #578163 is a reply to message #542622] Mon, 28 June 2010 05:54 Go to previous message
need to)
Simon
Previous Topic:e4 RC0, moved IEclipseContext where?
Next Topic:A breaking model change
Current Time: Sun Jul 20 12:24:33 EDT 2025
Powered by FUDForum. Page generated in 0.04869 seconds
