Temporary Repo Location [message #557990] |
Thu, 09 September 2010 13:26  |
Hi all,
I'm wondering if there is a way to temporarily register a repository with
the update manager.
I know I can use the IMetadataRepositoryManager and
IArtifactRepositoryManager to add repositories to the system permantently.
I'm looking for a way to add a repository location in such a way that it is
not persisted when the application shuts down.
Here's why:
I have a number of servers that are automatically detected by the system.
These servers frequently appear, disappear, and change their addresses.
Each time the application runs, it may be able to reach a completely
different set of servers.
I'm allowing each server to register itself as the host of a repository
while it is detected by my application but I would like to remove the
repository from the list when the server is no longer available. The best
way me to keep the repository list clean would be to re-add the repositories
each time the application launches.
Any help would be appreciated.
James
Re: Temporary Repo Location [message #631706 is a reply to message #558184] |
Fri, 08 October 2010 09:55   |
Thanks for the reply. I have gone the route of making a composite
repository even though an in-memory repository makes more sense in my mind.
The only remaining issue with this approach is that I can't seem to nest
composite repositories. That is, if the repository I'm trying to link to
from my composite repository is also a composite, it doesn't seem to work.
Is this actually the case? Is there a way to nest the composite?
Thanks again,
James
"Henrik Lindberg" <henrik.lindberg@cloudsmith.com> wrote in message
news:i6d9ti$h2l$1@build.eclipse.org...
> Have you looked at using a composite repository? Thinking that a refresh
> of that repository would pick up the changes in the contained
> repositories.
> This way, you would only need to add your dynamic repository once.
> Regards
> - henrik
> On 9/9/10 7:26 PM, James Peltzer wrote:
>> Hi all,
>> with the update manager.
>> permantently. I'm looking for a way to add a repository location in such
>> a way that it is not persisted when the application shuts down.
>> Here's why:
>> system. These servers frequently appear, disappear, and change their
>> addresses. Each time the application runs, it may be able to reach a
>> completely different set of servers.
>> best way me to keep the repository list clean would be to re-add the
>> repositories each time the application launches.
>> Thanks,
>> James
Re: Temporary Repo Location [message #631763 is a reply to message #631706] |
Fri, 08 October 2010 11:28  |
I would expect that to work...
One potential issue is if a repository changes type and was visitied by
clients - I seem to recall that there were issues with that - clients
may hold on to their belief the site is still in the old form.
I assume you have checked that the composite site is does not have a non
composite index, or that it is an old style update site at the same time.
To make sure it is not a caching issue like this, I would make sure to
start with a clean slate to make sure.
- henrik
> mind. The only remaining issue with this approach is that I can't seem
> to nest composite repositories. That is, if the repository I'm trying to
> link to from my composite repository is also a composite, it doesn't
> seem to work. Is this actually the case? Is there a way to nest the
> composite?
FUDForum. Page generated in 0.04559 seconds
