Home » Archived » Riena » UI Validation
UI Validation [message #14186] Mon, 13 October 2008 18:57 Go to next message
I've got a IValidator which can return more than one possible statuses.
How can I use a message from IStatus returned by this IValidator instead
of using a message which was set using a
IRidget.addValidationMessage(String) method?
Robert
Re: UI Validation [message #14203 is a reply to message #14186] Mon, 13 October 2008 19:22 Go to previous messageGo to next message
Robert Kwolek wrote:
As I can see one of possibilities is to use one message per validator
and to use IEditableRidget.addValidationMessage(String, IValidator). Are
there any other alternatives?
Robert
Re: UI Validation [message #14320 is a reply to message #14203] Thu, 16 October 2008 02:03 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
Hi Robert,
the current API does not support this use case.
Currently, the IValidator (i.e. validation rule) returns a message via
the IStatus object. However this message is subsequently ignored. If a
ValidationMessage exists for this rule, it is displayed -- but it
provides only a fixed string.
Personally, I would prefer to use the string from the IStatus directly.
I'm not sure why an additional ValidationMessage is necessary. However
I'm not very familiar with that API, so there might be a valid use case
for the ValidationMessage.
Can you file a bug to track this feature request?
I will discuss this with my colleagues and see what we can do.
Kind regards,
Elias.
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: UI Validation [message #15296 is a reply to message #14320] Thu, 16 October 2008 05:40 Go to previous message
Elias Volanakis wrote:
> Hi Robert,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=251060
By the way, consider such scenario: we have a person object with a birth
date (just 20081010) and special ID from which the birth date can be
extracted (e.g. "fdsfdsf20081010sds"). The validator shall check if the
birth date from the special ID and the "normal" birth date are the same.
Currently there is no way to provide such functionality without passing
the person object to validator outside the validation API.
I had the same problem in my previous project and the solution was
providing an extension point for the validation process.
All you had to do was implementing an interface with a method:
IStatus validate(Object object, String property);
where an object in our case would be a person object and a property
would be "birthDate" or "specialID".
Another advantage of such approach is that UI forms are separated from
validation (and vice versa ;-) ) and you can add validator without
modification of existing code.
Robert Kwolek
Re: UI Validation [message #576133 is a reply to message #14186] Mon, 13 October 2008 19:22 Go to previous message
Robert
Re: UI Validation [message #576299 is a reply to message #14203] Thu, 16 October 2008 02:03 Go to previous message
Hi Robert,
Kind regards,
Elias.
Elias Volanakis
Innoopract, Inc.
Re: UI Validation [message #576380 is a reply to message #14320] Thu, 16 October 2008 05:40 Go to previous message
> Hi Robert,
Robert Kwolek
Previous Topic:ITableRidget - nested properties
Next Topic:IObjectTransaction.addReference()
Current Time: Sun Jul 20 07:37:59 EDT 2025
Powered by FUDForum. Page generated in 0.06525 seconds
