Performance Improvements in loading xsd resource [message #26420] |
Sun, 17 August 2003 09:57  |
I would like to know if there's anyway I can improve the performance of
reading of an xsd schema. I run my code in a profiler a lot of the time is
spent in this part of the code. If I know that the xsd is valid, and I'm
not concerned about errors, is there something I can turn off while
reading?
I am currently using the following code:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "*",
new XSDResourceFactoryImpl());
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
final XSDResourceImpl xsdMainResource = (XSDResourceImpl)
resourceSet.getResource(uri, true);
XSDSchema xsdSchema = xsdMainResource.getSchema();
Hayden Marchant
Re: Performance Improvements in loading xsd resource [message #26455 is a reply to message #26420] |
Mon, 18 August 2003 08:11  |
Hayden,
Not tracking the location may speed things up a little, but other than that,
performance tuning in the model code is required.
> reading?
> Boolean.TRUE);
> Hayden Marchant
Re: Performance Improvements in loading xsd resource [message #575952 is a reply to message #26420] |
Hayden,
> reading?
> Boolean.TRUE);
> Hayden Marchant
FUDForum. Page generated in 0.03290 seconds
