Home » Eclipse Projects » EGit / JGit » How create Git repository from Eclipse project?
How create Git repository from Eclipse project? [message #474962] Wed, 05 August 2009 18:07 Go to next message
How can I use EGit to create a Git repository from sources that are
already in an Eclipse project? I found literature on how to import from a
Git repository, but nothing on exporting.
I'm running Eclipse 3.4.0, EGit 0.5.0, and Git 1.6.0.6.
Re: How create Git repository from Eclipse project? [message #476809 is a reply to message #474962] Wed, 05 August 2009 21:53 Go to previous messageGo to next message
EGit supports the common interface for Eclipse Team collaboration.
Right-click on your project and select Team -> Share Project. Select
Git and click Next. On the 'configure git repository' dialog, you may
have to select your project again. Then you should have the option to
Create the repository specified in the input line at the bottom of the
dialog (click Create). Then click Finish.
After that, you can right-click folders and do Team -> Add to Version
Control. The next step is to commit; until then, the repository will be
empty. What you have at this point is version control on your own
machine. You'll eventually want to push the contents of your repository
to another server. I use GitHub, so I don't have any guidance for how
to set up any other system. The guidance there is pretty good.
Good luck!
John
Re: How create Git repository from Eclipse project? [message #491067 is a reply to message #476809] Tue, 13 October 2009 02:03 Go to previous messageGo to next message
John Bito wrote on Wed, 05 August 2009 21:53
Then you should have the option to Create the repository specified in
the input line at the bottom of the dialog (click Create). Then click
Finish.
Actually this doesn't work as expected.
Re: How create Git repository from Eclipse project? [message #491324 is a reply to message #474962] Wed, 14 October 2009 03:26 Go to previous messageGo to next message
Have a look in the draft of the user guide we started recently and let us know if this is understandable and what you miss in this draft : http://wiki.eclipse.org/EGit/User_Guide/Getting_Started
Re: How create Git repository from Eclipse project? [message #573863 is a reply to message #474962] Wed, 05 August 2009 21:53 Go to previous messageGo to next message
Good luck!
John
Re: How create Git repository from Eclipse project? [message #574607 is a reply to message #476809] Tue, 13 October 2009 02:03 Go to previous messageGo to next message
> Finish.
Actually this https://bugs.eclipse.org/bugs/show_bug.cgi?id=291303 as expected.
Re: How create Git repository from Eclipse project? [message #574729 is a reply to message #474962] Wed, 14 October 2009 03:26 Go to previous message
Previous Topic:java.io.FileNotFoundException when checking out a branch
Next Topic:java.io.FileNotFoundException when checking out a branch
Current Time: Sat Jul 19 15:59:50 EDT 2025
Powered by FUDForum. Page generated in 0.23888 seconds
