CCXML editor invalidates valid CCXML codes [message #573877] |
Fri, 17 March 2006 15:24 |
The VTP CCXML editor invalidates CCXML codes which comply to W3C CCXML
stabdards v1.0.
It appears only follow the DTD: http://www.w3c.org/TR/ccxml/ccxml.dtd
which does not encompass the entire stabdard.
For example, the editor invalidates the following code:
<ccxma>
<eventhandler>
</venthandler>
</ccxml>
It displays a syntax hint according to the above mentioned DTD -- in which
"eventhandler" is not even defined.
How the CCXML editor perform syntax check and code completion?
May we add more name spaces -- DTD? in case of W3C CCXML standards, using
xsd files?
Or maybe even ABNF files?
Thanks.
FUDForum. Page generated in 0.03268 seconds
