compile, and generate and deploy failures [message #573346] |
Fri, 05 December 2003 09:44 |
Originally posted by: KLHolmes.open-iq.com
I have a seemingly random problem compiling some of the projects in my
workspace. Some projects will compile fine, others will consistently fail,
and I cant find the difference between them.
An AspectJ Error window pops up with "Compile failed. Reason: Compile
Failed"
As usual it seems to be a classpath problem, at the bottom I've attached
the resulting stacktrace from the .metadata/.log file.
I wondered if it might occur in projects which have no source files of
their own. All the projects in question are EJB projects which only hold
deployment descriptors and generated source files. Although there other
similar projects which compile just fine.
We're using WSAD 5.1 and any "generate and deploy" on an EJB project pops
up a "Cannot Generate Deployment Code" error with the following text
"Deployment of Player-Commerce-ejb did not complete successfully due to
the following error : java.lang.NullPointerException" This generates the
second stack trace listed below in the .metadata/.log file.
any ideas ?
regards,
Kevin Holmes.
!ENTRY org.eclipse.ajdt.ui 4 0 Dec 05, 2003 14:22:57.578
!MESSAGE Compile failed.
!STACK 0
at java.lang.Throwable.<init>(Throwable.java)
at java.lang.NullPointerException.<init>(NullPointerException.java:63)
at
org.eclipse.jdt.internal.launching.JRERuntimeClasspathEntryR esolver.resolveLibraryLocations(JRERuntimeClasspathEntryReso lver.java:51)
at
org.eclipse.jdt.internal.launching.JRERuntimeClasspathEntryR esolver.resolveRuntimeClasspathEntry(JRERuntimeClasspathEntr yResolver.java:43)
at
org.eclipse.jdt.internal.launching.RuntimeClasspathEntryReso lver.resolveRuntimeClasspathEntry(RuntimeClasspathEntryResol ver.java:81)
at
org.eclipse.jdt.launching.JavaRuntime.resolveRuntimeClasspat hEntry(JavaRuntime.java:879)
at
org.eclipse.ajdt.internal.ui.ajde.ProjectProperties.getClass path(ProjectProperties.java:205)
at org.eclipse.ajdt.internal.builder.Builder.build(Builder.java :150)
at
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:427)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java)
at org.eclipse.core.runtime.Platform.run(Platform.java)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:125)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:181)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:191)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:151)
at
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:165)
at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:265)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:85)
at
org.eclipse.ui.actions.BuildAction.invokeOperation(BuildActi on.java:156)
at
org.eclipse.ui.actions.WorkspaceAction.execute(WorkspaceActi on.java:122)
at
org.eclipse.ui.actions.WorkspaceAction$1.execute(WorkspaceAc tion.java:279)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:71)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1595)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:85)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
!ENTRY com.ibm.etools.ejbdeploy 4 0 Dec 05, 2003 14:44:44.421
!MESSAGE
!STACK 0
at
com.ibm.etools.ejbdeploy.plugin.JavacOperation.run(JavacOper ation.java:86)
at
com.ibm.etools.ejbdeploy.ui.plugin.DeployRMICBeansOperation. javac(DeployRMICBeansOperation.java:483)
at
com.ibm.etools.ejbdeploy.ui.plugin.DeployRMICBeansOperation. run(DeployRMICBeansOperation.java:561)
at
com.ibm.etools.ejbdeploy.ui.plugin.DeployRunnableWithProgres s.run(DeployRunnableWithProgress.java:92)
at
FUDForum. Page generated in 0.02961 seconds
