Home » Archived » IAM (Eclipse Integration for Apache Maven) » File org.eclipse.wst.common.component modified
File org.eclipse.wst.common.component modified [message #572384] Wed, 24 February 2010 20:44 Go to next message
Since i've upgraded to 0.11, the file "org.eclipse.wst.common.component" is modified each time I clean a web project.
Each time the folowing line is added to the file :
<wb-resource deploy-path="/WEB-INF/classes" source-path="/target/classes"/>
So after a couple of days, I end up with a file like that :
<project-modules id="moduleCoreId" project-version="1.5.0">
<wb-module deploy-name="TSPBnC">
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/Util/Util">
<dependency-type>uses</dependency-type>
</dependent-module>
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/AccesTSP/AccesTSP">
</dependent-module>
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/AccesGPS/AccesGPS">
</dependent-module>
<property name="context-root" value="TSPBnC"/>
<wb-resource deploy-path="/" source-path="src/main/webapp"/>
<property name="java-output-path" value="/target/classes"/>
<wb-resource deploy-path="/WEB-INF/classes" source-path="src/main/java"/>
<wb-resource deploy-path="/WEB-INF/classes" source-path="src/main/resources"/>
</wb-module>
</project-modules>
Does anyone have the same behavior?
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572410 is a reply to message #572384] Thu, 25 February 2010 16:04 Go to previous message
I noticed that too and fixed it already in the last 0.12 development build.
If you want to try the new build, it's available at
http://q4e.googlecode.com/svn/trunk/updatesite-dev/
http://code.google.com/p/q4e/wiki/Installation
> </dependent-module>
> </dependent-module>
> </dependent-module>
> </wb-module>
> </project-modules>
> Regards,
> Gabriel.
Previous Topic:Disable Dependecy Path Update
Next Topic:Package WAR gives NullPointer Exception
Current Time: Sat Jul 19 12:34:30 EDT 2025
Powered by FUDForum. Page generated in 0.05252 seconds
