Installation Directions for OHF Bridge [message #569933] |
Fri, 18 August 2006 17:55 |
I'd like to announce the initial set of instructions for installing the
OHF Bridge. Please note that this works with code checked in as of August
16th. There has been one code check in since then, and there are some
integration kinks being worked out. It is possible within CVS to check out
code only checked in by a certain date, and I would suggest this technique
until all of the kinks are ironed out. I will announce when this happens,
and update the install instructions accordingly. The link is here:
http://wiki.eclipse.org/index.php/Ohf_bridge#Bridge_Install_ Steps
Melih
FUDForum. Page generated in 0.07788 seconds
