RE: [stp-newsgroup] [STP-BS] Initial build system [message #569797] |
Mon, 19 December 2005 11:38 |
Originally posted by: CTRIELOFF.iona.com
I spoke to Bjorn, and it looks lie kit would be best to set this up with
one of the companies infrastructure involved. So we also need to be
able to post all the results back to the open list/ pages from the
build system.
Carl.
-----Original Message-----
Sent: Monday, December 19, 2005 9:52 AM
To: stp-newsgroup@eclipse.org
Subject: [stp-newsgroup] [STP-BS] Initial build system
Hi all,
I wanted to pick up the discussion from last week around an initial
build system. In my opinion that build system does not have to contain a
lot of stp runtime code, it may only contain a single placeholder class
and a single test.
The buildsystem should, however, contain the logic to
- Build a plugin
- Build tests for the plugin
- Execute the tests
- Capture code coverage of the tests
- Do all the above automatically from a script
Christophe, you mentioned that someone from Objectweb has done this
before, and would be able to contribute this to STP, could you outline
what this submission contains, and when it would be available?
I expect that we will have CVS (or even better: subversion) access any
time soon, probably straight after creation review.
Thanks!
David Bosschaert
IONA
_______________________________________________
stp-newsgroup mailing list
https://dev.eclipse.org/mailman/listinfo/stp-newsgroup
FUDForum. Page generated in 0.03259 seconds
