How to stop jetty:run from q4e 0.9? [message #568975] |
Wed, 13 May 2009 23:20 |
I can launch my web app via the jetty:run goal from within q4e OK.
But it shows as a non-terminating task in Eclipse's Progress view.
Canceling the task using the red button in progress view is ineffective.
If I subsequently attempt goal jetty:stop (the "right way"), the launch of
this goal appears to block on the previous jetty:run goal.
Does q4e/IAM serialize maven goal execution?
If so, this seems to be a big obstacle to it supporting common usage
patterns.
-Ben
PS I expect I can workaround issue from Maven command line. However, to
some extent this defeats purpose of having Eclipse integration, if one
must regularly drop out of it.
FUDForum. Page generated in 0.04106 seconds
