Home » Archived » Visual Editor (VE) » Install Problems
Install Problems [message #2698] Fri, 21 November 2003 01:08 Go to next message
I have a problem to use the visualeditor, I can use it (Elcipse 2.1.2).
There is no change to use it, there is no 'VisualClass' in my Eclipse.
I have installed the plugin correctly.
I have delete my Eclipse folder and installed new, but nothing has change.
What is my error ?!?!?
Re: Install Problems [message #3753 is a reply to message #2698] Fri, 21 November 2003 03:17 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
Kroll, Michael wrote:
Make sure that you installed also EMF and GEF.
Re: Install Problems [message #3806 is a reply to message #2698] Fri, 21 November 2003 09:46 Go to previous messageGo to next message
http://download.eclipse.org/tools/ve/downloads/drops/S-S2003 1113-200311131536/index.html
All you need to download is at that link (build sensitive, so it might
change). A couple of things to look out for. Install eclipse first, then
the other zips in that link. Remember that when you unzip (EMF, GEF,
VE), they need to be unzipped in the eclipse folder. If that doesn't
work, holler back and we'll see if we can find any other problems.
regards
Phil Muldoon
Red Hat
> Hello,
Re: Install Problems [message #3880 is a reply to message #3806] Sun, 23 November 2003 01:49 Go to previous messageGo to next message
Originally posted by: yanghua94.online.sh.cn
I experience the same problem yesterday...
I have installed EMF but EMF not installed.
"Phil Muldoon" <pmuldoon@redhat.com> ????
news:3FBE253B.9030508@redhat.com...
> regards
> Phil Muldoon
> Red Hat
> > Hello,
change.
Re: Install Problems [message #4058 is a reply to message #3880] Mon, 24 November 2003 01:04 Go to previous messageGo to next message
I found several versions of VE Runtime:
- Stable Build: S20031113 (Nov. 13 2003)
- 0.5.0 Stream Stable Build: 0.5.0RC1 (Fri, 21 Nov. 2003)
- 0.5.0 Stream Integration Build: I20031117 (Mon, 17 Nov 2003)
So, there are two stable builds and an integration build. The 0.5.0
Stream files comes from http://www.eclipse.org/vep/ and the first
from
http://download.eclipse.org/tools/ve/downloads/drops/S-S2003 1113-200311131536/index.html.
I think the latest stable is the second...
Francesc
> > regards
> > Phil Muldoon
> > Red Hat
> > > Hello,
> change.
Re: Install Problems [message #4406 is a reply to message #4058] Mon, 24 November 2003 10:51 Go to previous message
The latest stable build was built on Friday, 11/21 and contains fixes for
bugs found in the last test pass. It is a release candidate for the 0.5.0
release. You can get it from
http://download.eclipse.org/tools/ve/downloads/drops/S-0.5.0 RC1-200311211704
/index.html
Regards....
Peter Walker
"Francesc Ros
Re: Install Problems [message #567808 is a reply to message #2698] Fri, 21 November 2003 03:17 Go to previous message
Re: Install Problems [message #568086 is a reply to message #2698] Fri, 21 November 2003 09:46 Go to previous message
regards
Phil Muldoon
Red Hat
> Hello,
Re: Install Problems [message #568467 is a reply to message #3806] Sun, 23 November 2003 01:49 Go to previous message
> regards
> Phil Muldoon
> Red Hat
> > Hello,
change.
Re: Install Problems [message #568593 is a reply to message #3880] Mon, 24 November 2003 01:04 Go to previous message
from
Francesc
> > regards
> > Phil Muldoon
> > Red Hat
> > > Hello,
> change.
Re: Install Problems [message #568784 is a reply to message #4058] Mon, 24 November 2003 10:51 Go to previous message
/index.html
Regards....
Peter Walker
"Francesc Ros
Previous Topic:VE extension
Next Topic:GridBagLayour editor?
Current Time: Sat Jul 19 06:32:01 EDT 2025
Powered by FUDForum. Page generated in 0.07248 seconds
