Home » Eclipse Projects » Eclipse 4 » Develop reusable Custom Widgets In XWT
Develop reusable Custom Widgets In XWT [message #566042] Tue, 15 December 2009 06:10 Go to next message
Thanks for the answers from Yves YANG in e4 developer mailing list.
For example:
In your example, DecoratedText have property ,text, then the widgets will be used as following:
<Composite xmlns:c="clr-namespace:ext.custom">
<c:DecoratedText text="newWidgets" />
</Composite>
and :
DecoratedText.java
package ext.custom;
public class DecoratedText {
private String text;
// event handling methods
DecoratedText.xwt
<Composite x:Class="ext.custom.DecoratedText">
<Label text={xxxxxx??}/>
<Text/>
</Composite>
How to get the property text in DecoratedText.xwt and set it into a Label or others.
Re: Develop reusable Custom Widgets In XWT [message #566064 is a reply to message #566042] Tue, 15 December 2009 15:06 Go to previous messageGo to next message
> or others.
By now, you need to give them a name. and then call
XWT.findElementByName(context, "<name>");
<Label name="myText" text={xxxxxx??}/>
<Text/>
</Composite>
protected void eventHandle(Object sender, Event event) {
Text text = (Text) XWT.findElementByName(event.widget, "myText");
We are considering to provide automatic solution to initialize the class
Field to avoid the manuel research call
Best regards
Yves YANG
"Jinshan" <jinshanl@gmail.com> wrote in message
news:hg8ce9$hmb$1@build.eclipse.org...
> For example:
> </Composite>
> and :
> DecoratedText.java
> package ext.custom;
> DecoratedText.xwt
> <Text/>
> </Composite>
> or others.
> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566107 is a reply to message #566064] Tue, 15 December 2009 18:00 Go to previous message
Here is the bug for this feature:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297586
yves
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hg90to$fq7$1@build.eclipse.org...
>> or others.
> <Text/>
> </Composite>
> Best regards
> Yves YANG
>> For example:
>> </Composite>
>> and :
>> DecoratedText.java
>> package ext.custom;
>> DecoratedText.xwt
>> <Text/>
>> </Composite>
>> or others.
>> Thanks
Previous Topic:[xwt] Dynamic EMF data context not recognized
Next Topic:Application.xmi + Intro / Welcome Page
Current Time: Sun Jul 20 14:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.12981 seconds
