Package Not Found exception [message #565693] |
Thu, 26 August 2010 17:42  |
Hi there,
I would like to separate the pictogram model and the domain model as described in:
http://www.eclipse.org/forums/index.php?t=msg&th=172247& amp;start=0&S=c203ceb072b6812d39e0ac3742070175
Actually, I am able to create the model file in the src folder, e.g.,:
text.model
<?xml version="1.0" encoding="ASCII"?>
<BIM:Intention xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:BIM="platform:/resource/org.eclipse.graphiti.bim/src/BIM.ecore " name="Test"/>
BUT, if I close and reopen the enviroment, I have the following error markers:
Multilpe markers at this line:
-- ClassNotFoundException: Class 'Intention' is not found or is abstract. (platform:/resource/test/src/tests.model, 2, 152)
-- PackageNotFoundException: Package with uri 'platform:/resource/org.eclipse.graphiti.bim/src/BIM.ecore' not found. (platform:/resource/test/src/tests.model, 2, 152)
Should I register the package's uri in some place?
Much appreciated any help or suggestions on how to do that :)
Bye
Daniele
Re: Package Not Found exception [message #565741 is a reply to message #565693] |
Fri, 27 August 2010 02:47  |
This sounds as if there is something wrong with your EMF model in general.
Maybe you could check your extensions registered at
org.eclipse.emf.ecore.generated_package; your package should be registered
there. I doubt that this happens because of the separation of the domain
model.
For Graphiti no special registration is needed.
-Michael
"Daniele" <barone.daniele@gmail.com> wrote in message
news:i56n3o$2ft$1@build.eclipse.org...
> Hi there,
> described in:
> text.model
> name="Test"/>
> markers:
> Bye
> Daniele
FUDForum. Page generated in 0.68980 seconds
