Home » Archived » AM3 » Error installing AM3 in Ganymede
Error installing AM3 in Ganymede [message #374293] Fri, 21 November 2008 17:50 Go to next message
I tried to checkout AM3 from SVN as described here:
http://wiki.eclipse.org/AM3/How_Install_New_AM3_From_SVN, in latest
Eclipse Ganymede 3.4. And everything went O.K. But when I tried to export
those packages as "Deployable plug-ins and fragments", it works to 70% and
write this error:
Problems during export
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.pde.core \temp\org.eclipse.pde.container.feature\build.xml:84:
The following error occurred while executing this line:
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.pde.core \temp\org.eclipse.pde.container.feature\build.xml:55:
C:\eclipse\workspace\org.eclipse.gmt.am3.platform.extension. globalmodelmanagement\build.xml:194:
C:\eclipse\workspace\org.eclipse.gmt.am3.platform.extension. globalmodelmanagement\build.xml:166:
Failed to copy
C:\eclipse\workspace\org.eclipse.gmt.am3.platform.extension. globalmodelmanagement\temp.folder\@dot.bin\org\eclipse\gmt\a m3\platform\extension\globalmodelmanagement\transformationex ecutionengine\TransformationExecutionHelper.class
to
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.pde.core \temp\destination\plugins\org.eclipse.gmt.am3.platform.exten sion.globalmodelmanagement_0.4.0\@dot\org\eclipse\gmt\am3\pl atform\extension\globalmodelmanagement\transformationexecuti onengine\TransformationExecutionHelper.class
due to java.io.FileNotFoundException
(The system cannot find the path specified)
Failed to copy
to
Failed to copy
to
Failed to copy
to
What is the problem ?
Re: Error installing AM3 in Ganymede [message #374296 is a reply to message #374293] Wed, 26 November 2008 23:08 Go to previous messageGo to next message
did you have any problem to see the images in the
http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN ?
gab
Re: Error installing AM3 in Ganymede [message #374297 is a reply to message #374296] Thu, 27 November 2008 15:14 Go to previous messageGo to next message
No, I don't see figures!
Regards, Milan
Re: Error installing AM3 in Ganymede [message #374298 is a reply to message #374297] Wed, 03 December 2008 06:44 Go to previous messageGo to next message
Hi Milan,
> Regards, Milan
If you want the ATL ANT tasks & AM3 Resource Navigator, the old AM3
plugins are available as explained from
You have to checkout the sources of compatible ATL plugins from the
development branch as explained from
http://wiki.eclipse.org/ATL/How_Install_ATL_(Dev)_From_CVS
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
EMail: hugo.bruneliere@inria.fr
Re: Error installing AM3 in Ganymede [message #374299 is a reply to message #374298] Sun, 07 December 2008 07:03 Go to previous message
O.K. Thanks. But why you don't prepare binary version for Ganymede ? I
don't want to checkout from sources, because of all problems I can get in
generating those plugins.
Milan
Hugo Bruneliere wrote:
> Hi Milan,
> Milan Milanovich a ᅵcrit :
>> Regards, Milan
> Best regards,
> Hugo
Re: Error installing AM3 in Ganymede [message #563538 is a reply to message #374293] Wed, 26 November 2008 23:08 Go to previous message
gab
Re: Error installing AM3 in Ganymede [message #563562 is a reply to message #374296] Thu, 27 November 2008 15:14 Go to previous message
Regards, Milan
Re: Error installing AM3 in Ganymede [message #563581 is a reply to message #374297] Wed, 03 December 2008 06:44 Go to previous message
Hi Milan,
> Regards, Milan
Hugo
Re: Error installing AM3 in Ganymede [message #563606 is a reply to message #374298] Sun, 07 December 2008 07:03 Go to previous message
Milan
> Hi Milan,
>> Regards, Milan
> Best regards,
> Hugo
Previous Topic:Where are the zoos?
Next Topic:Ecore2KM3 Question
Current Time: Sun Jul 20 17:41:21 EDT 2025
Powered by FUDForum. Page generated in 0.08343 seconds
