Home » Archived » AM3 » RE: AM3 XML injector
RE: AM3 XML injector [message #374178] Mon, 03 November 2008 07:21 Go to next message
Does anyone know if AM3 still provides XML injector functionality? I have
AM3 installed and one of my ant scripts uses am3.loadModel for an XML
file, but is coming back with the following:
Buildfile: /Users/mark/Documents/workspace/mikael2.low.tran1/build.xml
loadModels:
[echo] load metamodels
BUILD FAILED
/Users/mark/Documents/workspace/mikael2.low.tran1/build.xml: 6: Problem:
failed to create task or type am3.loadModel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken
place.
Total time: 101 milliseconds
Any idea?
Mark
Re: AM3 XML injector [message #374179 is a reply to message #374178] Mon, 03 November 2008 09:20 Go to previous messageGo to next message
Hi Mark,
Mark Melia a écrit :
> have AM3 installed and one of my ant scripts uses am3.loadModel for an
> XML file, but is coming back with the following:
> loadModels:
> BUILD FAILED
> place.
> Any idea?
The problem is that the "am3.loadModel" task is not found. It does not
seem to come from the XML injection.
When you run the ANT script launching your task, do you specify that you
want to do it using the same JRE as the workspace?
This option needs to be checked from the "JRE" tab of your ANT script
launch configuration.
Hugo
> Mark
Re: AM3 XML injector [message #374181 is a reply to message #374179] Tue, 04 November 2008 07:04 Go to previous messageGo to next message
Hi Hugo,
Thanks for your reply
Yes I have done this but still no joy, yet I can get it to work with a
previous version on the eclipse CVS, any ideas?
Mark
Re: AM3 XML injector [message #374289 is a reply to message #374181] Mon, 17 November 2008 05:35 Go to previous messageGo to next message
Dear Mark,
> Hi Hugo,
>> you want to do it using the same JRE as the workspace?
> Regards,
> Mark
You seems to have a similar problem than Jerome so I propose you the
same answer ;-)
Due to some recent major modifications of the ATL HEAD version, the old
AM3 plugins (available as explained from
http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN) are currently not
compatible with this ATL version.
You have to checkout the sources of compatible ATL plugins from the
development branch as explained from
http://wiki.eclipse.org/ATL/How_Install_ATL_(Dev)_From_CVS
Sorry for any inconvenience.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
EMail: hugo.bruneliere@inria.fr
Re: AM3 XML injector [message #374302 is a reply to message #374289] Thu, 05 February 2009 08:00 Go to previous message
Hi Hego/Lisa,
Just to confirm the SVN plugins still do not support all the ant tasks.
Perhaps this should be highlighted on the SVN install page?
Ronan
Re: AM3 XML injector [message #563215 is a reply to message #374178] Mon, 03 November 2008 09:20 Go to previous message
Hi Mark,
> loadModels:
> BUILD FAILED
> place.
> Any idea?
Hugo
> Mark
Re: AM3 XML injector [message #563264 is a reply to message #374179] Tue, 04 November 2008 07:04 Go to previous message
Hi Hugo,
Mark
Re: AM3 XML injector [message #563375 is a reply to message #374181] Mon, 17 November 2008 05:35 Go to previous message
Dear Mark,
> Hi Hugo,
> Regards,
> Mark
same answer ;-)
Hugo
Re: AM3 XML injector [message #563678 is a reply to message #374289] Thu, 05 February 2009 08:00 Go to previous message
Hi Hego/Lisa,
Ronan
Previous Topic:Ecore2KM3 Question
Next Topic:Ecore2KM3 Question
Current Time: Sun Jul 20 09:57:33 EDT 2025
Powered by FUDForum. Page generated in 0.05046 seconds
