Home » Archived » GEF3D » Errors with GEF3D example
Errors with GEF3D example [message #496630] Tue, 10 November 2009 12:41 Go to next message
I was known GEF3D yesterday, and found it is really amazing!
I checked all the GEF3D materials that I can got, and I known there is no offical release till now, but I still can't wait to work with it.Smile
I set up the environment according to "http://wiki.eclipse.org/GEF3D_Installation", but I cannot make the examples work, here is the problem, hope somebody could help me, thank you in advance!
My Environment is HP 6510B laptop, and Vista Ultimate OS.
Steps:
1. Download "eclipse-modeling-galileo-SR1-incubation-win32.zip"
2. Checkout the projects(svn://dev.eclipse.org/svnroot/technology/org.eclipse.gef3d) and install "WJGL"
3. run as "Eclipse Application", then New->Examples->GEF3D Examples->GEF3D Graph Example Model, new a "test.G3D_graph" file with default settings.
4. Error occurs when open this file:
at java.util.Hashtable.put(Unknown Source)
at java.util.Properties.setProperty(Unknown Source)
at org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl.setPrope rty(Graphics3DLwjgl.java:750)
at org.eclipse.draw3d.LightweightSystem3D.setFontAntialias(Ligh tweightSystem3D.java:941)
at org.eclipse.draw3d.ui.preferences.ScenePreferenceDistributor .setSceneFontAntialias(ScenePreferenceDistributor.java:141)
at org.eclipse.draw3d.ui.preferences.ScenePreferenceDistributor .init(ScenePreferenceDistributor.java:99)
at org.eclipse.draw3d.ui.preferences.Draw3DPreferenceDistributo r.start(Draw3DPreferenceDistributor.java:52)
at org.eclipse.gef3d.ui.parts.GraphicalEditor3DWithPalette.doRe gisterToScene(GraphicalEditor3DWithPalette.java:131)
at org.eclipse.gef3d.ui.parts.GraphicalEditor3DWithPalette.crea teGraphicalViewer(GraphicalEditor3DWithPalette.java:71)
at org.eclipse.gef.ui.parts.GraphicalEditorWithPalette.createPa rtControl(GraphicalEditorWithPalette.java:62)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2857)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at org.eclipse.gef3d.examples.graph.editor.wizard.GraphWizard.p erformFinish(GraphWizard.java:223)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:752)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:253)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:273)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:294)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
5. Error will also ocurr when I new a file with .umlclass or .G3D_multi extension.(Attached detailed log)
Do you have any idea? Could you tell me what is the correct way to play with org.eclipse.gef3d.examples.ecore, graph and uml2?
Any help will be highly appriciated!
Joe
[Updated on: Tue, 10 November 2009 12:41] by Moderator
Re: Errors with GEF3D example [message #496631 is a reply to message #496630] Tue, 10 November 2009 12:48 Go to previous messageGo to next message
Attach the file
Re: Errors with GEF3D example [message #496690 is a reply to message #496630] Tue, 10 November 2009 18:00 Go to previous messageGo to next message
Hi Joe,
that is not your fault. I think I have introduced that bug. It's fixed
in an experimental branch and I will merge the fix into HEAD tomorrow.
Sorry about the inconvenience!
Best regards
Kristian
Re: Errors with GEF3D example [message #496700 is a reply to message #496690] Tue, 10 November 2009 22:17 Go to previous messageGo to next message
Thank you for your reply.
I've tried to find everything about GEF3D, just known there is an Germany article "GEF goes 3D" and 3 example codes, is there any other material I missed?
I really like this project, the only obstacle for GEF3D starter to explore is lacking of tutorials and do not know the correct way to play with the examples?
Re: Errors with GEF3D example [message #496747 is a reply to message #496700] Wed, 11 November 2009 04:22 Go to previous messageGo to next message
> material I missed?
There are some research papers, listed on the "Documentation" page
(http://www.eclipse.org/gef3d/website/docs/index.php ). I'm currently
working on the english version of the german tutorial article and I
hope it will be publicly available, soon.
Cheers
Jens
Re: Errors with GEF3D example [message #496757 is a reply to message #496630] Wed, 11 November 2009 05:04 Go to previous messageGo to next message
Hi again,
the problem is now fixed. You should update org.eclipse.draw3d.lwjgl.
Sorry again!
Best regards
Kristian
Re: Errors with GEF3D example [message #496914 is a reply to message #496757] Wed, 11 November 2009 12:52 Go to previous messageGo to next message
Yes, it works! Thank you.
By the way, I tried to open .umlclass file with 3D editor just returned an empy 3D editor, and seems cannot drag and drop the the other uml diagram to the 3D editor...
[Updated on: Wed, 11 November 2009 21:49] by Moderator
Re: Errors with GEF3D example [message #497033 is a reply to message #496914] Thu, 12 November 2009 05:33 Go to previous message
> By the way, I just know how to play with "graph" example, does anybody
> know how to play with "uml2" and "ecore" examples?
First of all, you need to install the UML2 Tools and the Ecore Tools.
That is, you should be able to create and edit UML diagrams and ecore
diagrams with the 2D editors (*.umlclass, *.umlusc, *.umlact,
*.ecorediag). Is that working? If so, you can now simply open these
diagrams with the 3D editors. For that, select "Open With" from the
context menu of the diagram files and choose a 3D editor, e.g. "UML
Tools Class Editor 3D". If you open a diagram with the "Multi Editor
3D", you should even be able to simply drag and drop other diagrams
onto the 3D scene, they will then be opened behind currently opened
diagram planes.
The 3D editors are more or less fully functional, we haven't integrated
context menus yet and there maybe the one or other feature missing.
Jens
Re: Errors with GEF3D example [message #563342 is a reply to message #496630] Tue, 10 November 2009 12:48 Go to previous message
Attach the file
Re: Errors with GEF3D example [message #563364 is a reply to message #496630] Tue, 10 November 2009 18:00 Go to previous message
Hi Joe,
Best regards
Kristian
Re: Errors with GEF3D example [message #563386 is a reply to message #496690] Tue, 10 November 2009 22:17 Go to previous message
Re: Errors with GEF3D example [message #563410 is a reply to message #563386] Wed, 11 November 2009 04:22 Go to previous message
> material I missed?
Cheers
Jens
Re: Errors with GEF3D example [message #563433 is a reply to message #496630] Wed, 11 November 2009 05:04 Go to previous message
Hi again,
Sorry again!
Best regards
Kristian
Re: Errors with GEF3D example [message #563455 is a reply to message #496757] Wed, 11 November 2009 12:52 Go to previous message
By the way, I just know how to play with "graph" example, does anybody know how to play with "uml2" and "ecore" examples?
Re: Errors with GEF3D example [message #563481 is a reply to message #563455] Thu, 12 November 2009 05:33 Go to previous message
diagram planes.
Jens
Previous Topic:Errors with GEF3D example
Next Topic:Re: GEF3D
Current Time: Sat Jul 19 22:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.11478 seconds
