Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » Build from Source Qs
Build from Source Qs [message #562752] Wed, 24 March 2010 09:14 Go to next message
I was trying to build STEM from source so I can start making a modified version, but am having trouble. The guidance I was using is here http://wiki.eclipse.org/index.php/STEM_Source_Code (to get source, which worked fine) and here http://wiki.eclipse.org/index.php/Installation_Guide (looking under Preparing to Run STEM as a STEM Developer).
I imported STEM (tried both the branches\STEM_1_0_0\ and trunk\ versions) into Eclipse. It builds everything it imports, but there were errors in a few packages. These were all due to failed imports from org.eclipse.birt. I looked up BIRT on the Eclipse site, and found this page to acquire it: http://wiki.eclipse.org/BIRT_Update_Site_URL
My Eclipse Platform is
Version: 3.5.2.R35x_v20100210-0800-9hEiFzmFst-TiEn9hNYgDWg1XN8ulH_JvC NGB
Build id: M20100211-1343
so I tried the BIRT 2.5.x milestone build which says it is compatible with Eclipse Platform 3.5.2. (I also tried the release build for Eclipse 3.5, just to see).
The STEM imports for BIRT are now alright, but STEM still won't start. I use the ANT script to build the internal data, then try to run the UI package. The STEM splash screen comes up, then I get the error pasted below.
I looked around a little online, but am not experienced with Eclipse and was hoping someone else will know right away how to resolve this. There looks to be a version error for org.eclipse.ecf.provider.filetransfer_3.0.1. In my plugins folder I have: org.eclipse.ecf.provider.filetransfer_3.0.1.v20090831-1906.j ar
Full error log below.
Doug
!SESSION 2010-03-23 17:53:09.482 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
Framework arguments: -product org.eclipse.stem.ui.product
Command-line arguments: -product org.eclipse.stem.ui.product -data C:\Documents and Settings\drafalsk\workspace/../runtime-stem.product -dev file:C:/Documents and Settings/drafalsk/workspace/.metadata/.plugins/org.eclipse.p de.core/stem.product/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2010-03-23 17:53:10.670
!MESSAGE Product org.eclipse.stem.ui.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2010-03-23 17:53:10.685
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2010-03-23 17:53:10.717
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.717
!MESSAGE Bundle initial@reference :file:plugins/org.eclipse.equinox.p2.repository_1.0.1.R35x_v 20100105.jar/ was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.repository 2 0 2010-03-23 17:53:10.717
!MESSAGE Missing required bundle org.eclipse.ecf.provider.filetransfer_3.0.1.
!ENTRY org.eclipse.osgi 2 0 2010-03-23 17:53:10.732
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.equinox.p2.metadata.repository_1.0.101.R35x_v200 90812 [64] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.persistence_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.repository.helpers_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.repository_0.0.0 .
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.spi.p2.repository_0 .0.0.
!MESSAGE Bundle org.eclipse.ui.navigator.resources_3.4.1.M20090826-0800 [101] was not resolved.
!SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.5.0,4.0.0).
!MESSAGE Bundle org.eclipse.ui.ide_3.5.2.M20100113-0800 [102] was not resolved.
!SUBENTRY 2 org.eclipse.ui.ide 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.equinox.p2.engine_[1.0.100,2.0.0).
!MESSAGE Bundle org.eclipse.equinox.p2.artifact.repository_1.0.101.R35x_v200 90721 [106] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.equinox.p2.engine_1.0.102.R35x_v20091117 [114] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.equinox.p2.metadata.repository_1.0.100.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0 .
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.metadata.reposit ory_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository_0.0.0.
!MESSAGE Bundle org.eclipse.ui.win32_3.2.100.v20090429-1800 [115] was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Bundle org.eclipse.equinox.p2.repository_1.0.1.R35x_v20100105 [117] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.diseasemodels.forcing_1.0.0.qualifier [721] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.forcing 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.definitions_0.0.0.
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.population.human.mo dels_1.0.0.qualifier [724] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.population.human.mo dels 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.internal.data_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.internal.data.geography_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.internal.data.geography.models_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.populationmodels_1.0.0 [727] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.populationmodels 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.populationmodels_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.ui_0.0.0.
!MESSAGE Bundle org.eclipse.stem.populationmodels_1.0.0 [728] was not resolved.
!SUBENTRY 2 org.eclipse.stem.populationmodels 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.population_1.0.0.qu alifier [730] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.population 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.infrastructure.tran sportation_1.0.0.qualifier [731] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.infrastructure.tran sportation 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.transport_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.reports_1.0.0.qualifier [733] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.reports 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.diseasemodels.externaldatasource_1.0.0.qual ifier [734] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.externaldatasource 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.util.analysis_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.ge_1.0.0.qualifier [736] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.ge 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.solvers.rk_1.0.0 [737] was not resolved.
!SUBENTRY 2 org.eclipse.stem.solvers.rk 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.analysis.automaticexperiment_1.0.0.qualifie r [738] was not resolved.
!SUBENTRY 2 org.eclipse.stem.analysis.automaticexperiment 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.util.loggers_0.0.0.
!MESSAGE Bundle org.eclipse.stem.definitions_1.0.0.qualifier [741] was not resolved.
!SUBENTRY 2 org.eclipse.stem.definitions 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.diseasemodels.scenarios_1.0.0.qual ifier [742] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.diseasemodels.scenarios 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data.geography_1.0.0.qualifier [745] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.solvers.fd_1.0.0 [746] was not resolved.
!SUBENTRY 2 org.eclipse.stem.solvers.fd 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.diseasemodels_1.0.0.qualifier [748] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.models_1.0.0.qualif icer [749] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.models 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.externaldatasource_1.0.0.q ualifier [750] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.externaldatasource 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.externaldatasource_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.ui.diseasemodels_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.example_1.0.0.qualifier [751] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.example 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.example_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels_1.0.0.qualifier [752] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.ui.navigator.resources_0.0.0.
!MESSAGE Bundle org.eclipse.stem.transport_1.0.0.qualifier [754] was not resolved.
!SUBENTRY 2 org.eclipse.stem.transport 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui_1.0.0.qualifier [755] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.util.analysis_1.0.0.qualifier [756] was not resolved.
!SUBENTRY 2 org.eclipse.stem.util.analysis 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.forcing.editor_1.0.0.quali fier [757] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.forcing.editor 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.forcing_0.0.0.
!MESSAGE Bundle org.eclipse.stem.util.loggers_1.0.0.qualifier [758] was not resolved.
!SUBENTRY 2 org.eclipse.stem.util.loggers 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data_1.0.0.qualifier [760] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.diseasemodels.models_1.0.0.qualifi er [761] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.diseasemodels.models 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.solvers.rk_1.0.0 [762] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.solvers.rk 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.solvers.rk_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_3.4.2.
!MESSAGE Bundle org.eclipse.stem.diseasemodels.example_1.0.0.qualifier [763] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.example 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.nl1_1.0.0.qualifier [766] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.nl1 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing host org.eclipse.stem.ui_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.solvers.fd_1.0.0 [767] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.solvers.fd 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.solvers.fd_0.0.0.
Re: Build from Source Qs [message #562780 is a reply to message #562752] Wed, 24 March 2010 15:05 Go to previous messageGo to next message
Hi Doug,
the easy stuff first, can you try this and see if it works:
1. In Eclipse, Java Perspective, Open the "Run Configurations..."
2. Select stem.product in the tree in the left.
3. On the right, click the Plug-ins tab.
4. Click "Add Required Plug-ins"
5. Click Apply.
6. Click "Validate plugins"
7. If it says No problems was detected, click run
8. If you see a problem, can you paste it?
Thanks!
Re: Build from Source Qs [message #562826 is a reply to message #562780] Wed, 24 March 2010 16:51 Go to previous messageGo to next message
Thanks for the suggestion. It was able to add the missing filetransfer plugin, and now it runs.
Re: Build from Source Qs [message #562848 is a reply to message #562826] Wed, 24 March 2010 17:25 Go to previous messageGo to next message
...though I can't seem to export a stand-alone version. Per http://wiki.eclipse.org/Welcome_STEM_Developers, I open feature.product and try to export a standalone version (tried to export to archive and directory), but I get:
Unable to find plug-in: org.eclipse.equinox.launcher_1.0.200.v20090520. Please check the error log for more details.
Suggestions there?
Re: Build from Source Qs [message #562870 is a reply to message #562848] Wed, 24 March 2010 18:11 Go to previous messageGo to next message
That doc seems a little out-of-date, we should fix.
Can you try opening the file "stem.product" instead, and selecting "Eclipse Product Export Wizard" from the overview tab.
Uncheck sync before exporting, pick a directory and change the root directory to "stem".
Does that work?
Re: Build from Source Qs [message #562893 is a reply to message #562870] Mon, 29 March 2010 09:50 Go to previous messageGo to next message
I opened stem.product and tried to export (unchecking synch but leaving everything else at its defailts) to a directory, and I get
Under testing, if I select 'Launch an Eclipse application' it runs (though I had to go in to dependencies first and click 'Add Required Plug-ins' first). It is just the exporting that seems problematic.
Re: Build from Source Qs [message #562917 is a reply to message #562893] Mon, 29 March 2010 19:19 Go to previous messageGo to next message
I tried it and was unable to export too. Can you open a defect on it? How badly do you need to be able to export?
Thanks.
/ Stefan
Re: Build from Source Qs [message #562939 is a reply to message #562917] Tue, 30 March 2010 09:21 Go to previous messageGo to next message
I am not sure how badly I need it just yet. Per http://www.eclipse.org/forums/index.php?t=msg&th=164822& amp;start=0&, I am investigating whether I can use STEM from a web interface. There wasn't currently one available, so I wanted to be able to create a non-UI version that I can call as a command line program, or possibly integrate with a web application.
I was exploring STEM and wanted to make sure I could create the standard installation to make sure my environment is set up properly before trying to muck about.
Re: Build from Source Qs [message #562987 is a reply to message #562939] Tue, 30 March 2010 10:15 Go to previous messageGo to next message
Any idea how long an issue like this takes to get resolved? It has to be some simple configuration issue I am just not experienced enough with Eclipse or STEM to diagnose. Someone must be able to do it though, I was using an exported executable version before I started trying to build it from source. It must be some simple configuration issue. I'm submitting a bug now.
Re: Build from Source Qs [message #563009 is a reply to message #562752] Tue, 30 March 2010 14:51 Go to previous messageGo to next message
Hi Doug, I posted a comment in the bug. Please try those steps and see if it works.
Re: Build from Source Qs [message #563060 is a reply to message #563009] Thu, 01 April 2010 09:18 Go to previous messageGo to next message
Matthew Davis wrote on Tue, 30 March 2010 14:51
I kept having the same error, so I decided to start clean for this, just in case. I blew away the source directory and grabbed it from SVN again. I imported trunk into my workspace. I followed the steps you posted in the DR (updated plugins under stem.product dependencies - it went from 163 to 165, then I saved). I get the same error regardless of whether synch is checked or not. ("Unable to find plug-in: org.eclipse.equinox.launcher_1.0.200.v20090520. Please check the error log for more details.") The session data from the error log event details:
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.reporting.product
I still can run it as an Eclipse application...
Re: Build from Source Qs [message #563085 is a reply to message #563060] Tue, 06 April 2010 17:17 Go to previous messageGo to next message
Any other thoughts?
Re: Build from Source Qs [message #563132 is a reply to message #562752] Tue, 06 April 2010 17:42 Go to previous message
Hi Doug, with Matt's new stem.product file I'm able to do the export (thanks Matt!). Does your error log file has any more useful information as indicated in the error message?
Previous Topic:Web interface?
Next Topic:Dependence on administrative regions
Current Time: Sat Jul 19 11:59:22 EDT 2025
Powered by FUDForum. Page generated in 0.05305 seconds
