Build from Source Qs [message #562752] |
Wed, 24 March 2010 09:14  |
I was trying to build STEM from source so I can start making a modified version, but am having trouble. The guidance I was using is here http://wiki.eclipse.org/index.php/STEM_Source_Code (to get source, which worked fine) and here http://wiki.eclipse.org/index.php/Installation_Guide (looking under Preparing to Run STEM as a STEM Developer).
I imported STEM (tried both the branches\STEM_1_0_0\ and trunk\ versions) into Eclipse. It builds everything it imports, but there were errors in a few packages. These were all due to failed imports from org.eclipse.birt. I looked up BIRT on the Eclipse site, and found this page to acquire it: http://wiki.eclipse.org/BIRT_Update_Site_URL
My Eclipse Platform is
Version: 3.5.2.R35x_v20100210-0800-9hEiFzmFst-TiEn9hNYgDWg1XN8ulH_JvC NGB
Build id: M20100211-1343
so I tried the BIRT 2.5.x milestone build which says it is compatible with Eclipse Platform 3.5.2. (I also tried the release build for Eclipse 3.5, just to see).
The STEM imports for BIRT are now alright, but STEM still won't start. I use the ANT script to build the internal data, then try to run the UI package. The STEM splash screen comes up, then I get the error pasted below.
I looked around a little online, but am not experienced with Eclipse and was hoping someone else will know right away how to resolve this. There looks to be a version error for org.eclipse.ecf.provider.filetransfer_3.0.1. In my plugins folder I have: org.eclipse.ecf.provider.filetransfer_3.0.1.v20090831-1906.j ar
Full error log below.
Doug
!SESSION 2010-03-23 17:53:09.482 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
Framework arguments: -product org.eclipse.stem.ui.product
Command-line arguments: -product org.eclipse.stem.ui.product -data C:\Documents and Settings\drafalsk\workspace/../runtime-stem.product -dev file:C:/Documents and Settings/drafalsk/workspace/.metadata/.plugins/org.eclipse.p de.core/stem.product/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2010-03-23 17:53:10.670
!MESSAGE Product org.eclipse.stem.ui.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2010-03-23 17:53:10.685
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2010-03-23 17:53:10.717
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.717
!MESSAGE Bundle initial@reference :file:plugins/org.eclipse.equinox.p2.repository_1.0.1.R35x_v 20100105.jar/ was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.repository 2 0 2010-03-23 17:53:10.717
!MESSAGE Missing required bundle org.eclipse.ecf.provider.filetransfer_3.0.1.
!ENTRY org.eclipse.osgi 2 0 2010-03-23 17:53:10.732
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.equinox.p2.metadata.repository_1.0.101.R35x_v200 90812 [64] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.persistence_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.repository.helpers_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.repository_0.0.0 .
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.spi.p2.repository_0 .0.0.
!MESSAGE Bundle org.eclipse.ui.navigator.resources_3.4.1.M20090826-0800 [101] was not resolved.
!SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.5.0,4.0.0).
!MESSAGE Bundle org.eclipse.ui.ide_3.5.2.M20100113-0800 [102] was not resolved.
!SUBENTRY 2 org.eclipse.ui.ide 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.equinox.p2.engine_[1.0.100,2.0.0).
!MESSAGE Bundle org.eclipse.equinox.p2.artifact.repository_1.0.101.R35x_v200 90721 [106] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.equinox.p2.engine_1.0.102.R35x_v20091117 [114] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.equinox.p2.metadata.repository_1.0.100.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0 .
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.p2.metadata.reposit ory_0.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository_0.0.0.
!MESSAGE Bundle org.eclipse.ui.win32_3.2.100.v20090429-1800 [115] was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Bundle org.eclipse.equinox.p2.repository_1.0.1.R35x_v20100105 [117] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.repository 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.diseasemodels.forcing_1.0.0.qualifier [721] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.forcing 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.definitions_0.0.0.
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.population.human.mo dels_1.0.0.qualifier [724] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.population.human.mo dels 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.internal.data_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.internal.data.geography_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.internal.data.geography.models_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.populationmodels_1.0.0 [727] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.populationmodels 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.populationmodels_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.ui_0.0.0.
!MESSAGE Bundle org.eclipse.stem.populationmodels_1.0.0 [728] was not resolved.
!SUBENTRY 2 org.eclipse.stem.populationmodels 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.population_1.0.0.qu alifier [730] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.population 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.infrastructure.tran sportation_1.0.0.qualifier [731] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.infrastructure.tran sportation 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.transport_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.reports_1.0.0.qualifier [733] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.reports 2 0 2010-03-23 17:53:10.732
!MESSAGE Bundle org.eclipse.stem.diseasemodels.externaldatasource_1.0.0.qual ifier [734] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.externaldatasource 2 0 2010-03-23 17:53:10.732
!MESSAGE Missing required bundle org.eclipse.stem.util.analysis_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.ge_1.0.0.qualifier [736] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.ge 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.solvers.rk_1.0.0 [737] was not resolved.
!SUBENTRY 2 org.eclipse.stem.solvers.rk 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.analysis.automaticexperiment_1.0.0.qualifie r [738] was not resolved.
!SUBENTRY 2 org.eclipse.stem.analysis.automaticexperiment 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.util.loggers_0.0.0.
!MESSAGE Bundle org.eclipse.stem.definitions_1.0.0.qualifier [741] was not resolved.
!SUBENTRY 2 org.eclipse.stem.definitions 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.diseasemodels.scenarios_1.0.0.qual ifier [742] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.diseasemodels.scenarios 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data.geography_1.0.0.qualifier [745] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.solvers.fd_1.0.0 [746] was not resolved.
!SUBENTRY 2 org.eclipse.stem.solvers.fd 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.diseasemodels_1.0.0.qualifier [748] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data.geography.models_1.0.0.qualif icer [749] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data.geography.models 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.externaldatasource_1.0.0.q ualifier [750] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.externaldatasource 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.externaldatasource_0.0.0.
!MESSAGE Missing required bundle org.eclipse.stem.ui.diseasemodels_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.example_1.0.0.qualifier [751] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.example 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.example_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels_1.0.0.qualifier [752] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.ui.navigator.resources_0.0.0.
!MESSAGE Bundle org.eclipse.stem.transport_1.0.0.qualifier [754] was not resolved.
!SUBENTRY 2 org.eclipse.stem.transport 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui_1.0.0.qualifier [755] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.util.analysis_1.0.0.qualifier [756] was not resolved.
!SUBENTRY 2 org.eclipse.stem.util.analysis 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.diseasemodels.forcing.editor_1.0.0.quali fier [757] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.diseasemodels.forcing.editor 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.diseasemodels.forcing_0.0.0.
!MESSAGE Bundle org.eclipse.stem.util.loggers_1.0.0.qualifier [758] was not resolved.
!SUBENTRY 2 org.eclipse.stem.util.loggers 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.data_1.0.0.qualifier [760] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.data 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.internal.diseasemodels.models_1.0.0.qualifi er [761] was not resolved.
!SUBENTRY 2 org.eclipse.stem.internal.diseasemodels.models 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.solvers.rk_1.0.0 [762] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.solvers.rk 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.solvers.rk_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_3.4.2.
!MESSAGE Bundle org.eclipse.stem.diseasemodels.example_1.0.0.qualifier [763] was not resolved.
!SUBENTRY 2 org.eclipse.stem.diseasemodels.example 2 0 2010-03-23 17:53:10.748
!MESSAGE Bundle org.eclipse.stem.ui.nl1_1.0.0.qualifier [766] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.nl1 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing host org.eclipse.stem.ui_0.0.0.
!MESSAGE Bundle org.eclipse.stem.ui.solvers.fd_1.0.0 [767] was not resolved.
!SUBENTRY 2 org.eclipse.stem.ui.solvers.fd 2 0 2010-03-23 17:53:10.748
!MESSAGE Missing required bundle org.eclipse.stem.solvers.fd_0.0.0.
Re: Build from Source Qs [message #563132 is a reply to message #562752] |
Tue, 06 April 2010 17:42  |
Hi Doug, with Matt's new stem.product file I'm able to do the export (thanks Matt!). Does your error log file has any more useful information as indicated in the error message?
FUDForum. Page generated in 0.31676 seconds
