Home » Archived » GMT (Generative Modeling Technologies) » [oaw] metamodel referencing
[oaw] metamodel referencing [message #562565] Fri, 16 February 2007 15:20
We have a metamodel for our DSL that references the UML2 metamodel.
When we refer to a UML2 metamodel element like this
http://www.eclipse.org/uml2/2.0.0/UML#//Property
It works fine when using a model based on this metamodel in a oaw workflow.
The standard ecore editor saves the UML2 references like this however:
.../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Prop erty
and that trips up the oaw workflow with an exception like stated below.
Is there a way to make these relative metamodel references work in oaw?
I did put my vote up in bugzilla for emf to have a choice between relative
or absolute referencing registered plugin models, but in the mean time it
would be great if you could support the relative referencing as well.
Hans
1663 ERROR WorkflowRunner -
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value
'MyElementName' is not legal.
(file:/C:/Documents%20and%20Settings/Hans/Eclipse%203.3%20pr ojects/my.generator.project/bin/model/test.model,
3, 105)
at org.openarchitectureware.emf.XmiReader.invoke(XmiReader.java :83)
at
org.openarchitectureware.workflow.container.CompositeCompone nt.internalInvoke(CompositeComponent.java:81)
at
org.openarchitectureware.workflow.container.CompositeCompone nt.invoke(CompositeComponent.java:69)
at
org.openarchitectureware.workflow.WorkflowRunner.executeWork flow(WorkflowRunner.java:236)
at
org.openarchitectureware.workflow.WorkflowRunner.run(Workflo wRunner.java:177)
at
org.openarchitectureware.workflow.WorkflowRunner.main(Workfl owRunner.java:126)
Previous Topic:[Announce] EclipseCon 2007 Registration
Next Topic:xText Startup Questions
Current Time: Sat Jul 19 20:47:32 EDT 2025
Powered by FUDForum. Page generated in 0.04680 seconds
