Home » Archived » Higgins » Problem Running Demo App and Saving Context
Problem Running Demo App and Saving Context [message #561682] Thu, 13 April 2006 13:31
Hi everyone, I'm trying to run the demo application, and received some
problem with running Demo App 1 and 2 to share profiles. I can launch the
ECF Server Application without problem. However, when I launch the demo
apps, I could not see the facet information I saved in app1 from app2. I'm
including below the console output that highlights the following errors:
1. classnotfoundexpection with
org.eclipse.ecf.provider.rss.http.Client$Creator
this happens when i initally launch the Demo App GUI
2. nullpointerexception at
org.eclipse.higgins.context.store.ProjectFolder.associateRes ource(ProjectFolder.java:133)
this happens when i try to save the changes made to a profile from the
demo app GUI
I'm using the following configuations and plugins in Eclipse:
Eclipse-SDK-3.1-win32
Eclipse Modeling Framework (EMF) 2.2.0v200604060931
EMF Service Data Objects (SDO) 2.2.0v200604060931
EODM SDK 1.0.0.v200603021130
ECF 0.7.6
When I first downloaded Higgins plugins from CVS using
http://www.eclipse.org/higgins/org.eclipse.higgins.docs/higg ins-anonymous.psf, i
had to download separately the org.eclipse.ecf.provider.rss and
org.eclipsehiggins.context.rss to resolve compile problems in
orgeclipse.higgins.test. i also had to modify "Higins Demo App 1.lanuch"
file to include all workspace and enabled external plugins. Otherwise, the
demo app GUI will not launch. These changes were not documented in the
installation instructions, and I'm not sure if i missed something else.
Console output is pasted below, please adivce. Thanks!
Simon
!SESSION 2006-04-13
12:59:22.515 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_06
Framework arguments: -application
org.eclipse.higgins.app.RcpApplication -pdelaunch
Command-line arguments: -application
org.eclipse.higgins.app.RcpApplication -data runtime\workspace -dev
file:C:/workspace3/.metadata/.plugins/org.eclipse.pde.core/H iggins Demo App
1/dev.properties -pdelaunch -consoleLog -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.higgins.internal 1 0 2006-04-13 12:59:23.375
!MESSAGE Higgins starting
Processing xid=org.eclipse.higgins.context.profileshare.context, member
name=context
Processing xid=org.eclipse.higgins.context.user.context, member name=context
Processing xid=org.eclipse.higgins.context.example.context, member
name=context
Processing xid=org.eclipse.higgins.context.rss.context, member name=context
!ENTRY org.eclipse.ecf 4 20 2006-04-13 12:59:24.500
!MESSAGE
!ExtPointError.ContainerNameCollisionPrefix!org.eclipse.ecf. provider.rss.Client!ExtPointError.ContainerNameCollisionSuff ix!org.eclipse.ecf.containerFactory
!ENTRY org.eclipse.core.runtime 4 1 2006-04-13 12:59:24.546
!MESSAGE Plug-in org.eclipse.ecf.provider.rss was unable to load class
org.eclipse.ecf.provider.rss.http.Client$Creator.
!STACK 0
java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at
org.eclipse.ecf.internal.core.ECFPlugin.addCommExtensions(EC FPlugin.java:536)
at
org.eclipse.ecf.internal.core.ECFPlugin.setupCommExtensionPo int(ECFPlugin.java:595)
at org.eclipse.ecf.internal.core.ECFPlugin.start(ECFPlugin.java :645)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:313)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
at
at
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:122)
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:82)
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
at
at
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at
org.eclipse.higgins.context.profileshare.plugin.ProfileShare Plugin.start(ProfileSharePlugin.java:82)
at
at
at
at
at
at
org.eclipse.higgins.internal.ProcessExtensions.demandLoad(Pr ocessExtensions.java:68)
at
org.eclipse.higgins.internal.ContextExtensionRegistry.demand LoadExtensions(ContextExtensionRegistry.java:80)
at org.eclipse.higgins.internal.Higgins.open(Higgins.java:99)
at
org.eclipse.higgins.app.RcpWorkbenchAdvisor.initPlatform(Rcp WorkbenchAdvisor.java:174)
at
org.eclipse.higgins.app.RcpWorkbenchAdvisor.preWindowOpen(Rc pWorkbenchAdvisor.java:148)
at
org.eclipse.ui.internal.application.CompatibilityWorkbenchWi ndowAdvisor.preWindowOpen(CompatibilityWorkbenchWindowAdviso r.java:45)
at
org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(Wo rkbenchWindow.java:1038)
at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:304)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workben ch.java:1173)
at
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:662)
at
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1282)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1223)
at
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.higgins.app.RcpApplication.run(RcpApplication.ja va:24)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Processing xid=org.eclipse.higgins.context.store.contextStore, member
name=contextStore
Open context: extensionId=org.eclipse.higgins.context.user.context id=Other
Person
Open context: extensionId=org.eclipse.higgins.context.user.context id=Simon
!ENTRY org.eclipse.ui 4 4 2006-04-13 12:59:26.609Invalid Menu Extension
(Path is invalid): converstLineDelimitersTo
Invalid Menu Extension (Path is invalid):
org.eclipse.ui.edit.text.delimiter.macOS9
org.eclipse.ui.edit.text.delimiter.unix
!MESSAGE Invalid Menu Extension (Path is invalid): converstLineDelimitersTo
!ENTRY org.eclipse.ui 4 4 2006-04-13 12:59:26.625
org.eclipse.ui.edit.text.delimiter.windows
org.eclipse.ui.edit.text.openExternalFile
org.eclipse.update.ui.updateMenu
!ENTRY org.eclipse.ui 4 4 2006-04-13 12:59:26.640
org.eclipse.update.ui.configManager
org.eclipse.update.ui.newUpdates
org.eclipse.ui.actions.showKeyAssistHandler
!ENTRY org.eclipse.ui 4 4 2006-04-13 12:59:26.656
org.eclipse.ui.edit.text.gotoLastEditPosition
org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.updateMenu
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.newUpdates
rc=1 rc == Window.OK ? false rc == Window.CANCEL ? true
rc=0 rc == Window.OK ? true rc == Window.CANCEL ? false
Open context: extensionId=org.eclipse.higgins.context.profileshare.context
id=ps1
!ENTRY org.eclipse.higgins.context.profileshare 1 0 2006-04-13 13:08:39.453
!MESSAGE ProfileShare start
!ENTRY org.eclipse.higgins.context.profileshare 1 0 2006-04-13 13:08:39.906
!ENTRY org.eclipse.higgins.context.model 1 0 2006-04-13 13:08:40.46
!MESSAGE Context: new IFacet name=demo1
!ENTRY org.eclipse.higgins.context.model 1 0 2006-04-13 13:08:40.218
at
at
org.eclipse.higgins.context.store.ProjectFolder.preSave(Proj ectFolder.java:105)
at
org.eclipse.higgins.context.store.ProjectFolder.writeFile(Pr ojectFolder.java:70)
at
org.eclipse.higgins.context.store.ContextStore.write0(Contex tStore.java:76)
at
org.eclipse.higgins.context.store.ContextStore.write(Context Store.java:48)
at
org.eclipse.higgins.context.store.WrappedContextStore.write( WrappedContextStore.java:39)
at
org.eclipse.higgins.context.model.persistence.model.impl.IPe rsistentContextImpl.sync(IPersistentContextImpl.java:244)
at
org.eclipse.higgins.internal.Higgins$SyncOperation.process(H iggins.java:260)
at
org.eclipse.higgins.internal.Higgins.walkContextLinkTree(Hig gins.java:540)
at org.eclipse.higgins.internal.Higgins.sync(Higgins.java:254)
at org.eclipse.higgins.app.actions.SaveAction.run(SaveAction.ja va:31)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
at
at
at
Previous Topic:ALF propsal
Next Topic:Problem Running Demo App and Saving Context
Current Time: Sun Jul 20 13:29:04 EDT 2025
Powered by FUDForum. Page generated in 0.05007 seconds
