Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » STEM Milestone M2 is now Available!!(STEM Milestone M2 is now Available!!)
STEM Milestone M2 is now Available!! [message #491933] Fri, 16 October 2009 11:22 Go to next message
Re: STEM Milestone M2 is now Available!! [message #492383 is a reply to message #491933] Tue, 20 October 2009 06:27 Go to previous messageGo to next message
Hi all,
congratulation for successfully reaching the milestone!
Are there already plans for the next development phase?
While reading through the bugzilla entries I found that one issue that I would appreciate very much has already been raised before: a possibility to generate modified graphs within the standalone STEM version and a possibility to visualize the graphs independently from the simulation. Has this already been considered or didn't I simply find the way to do it?
Matthias
Re: STEM Milestone M2 is now Available!! [message #492794 is a reply to message #492383] Wed, 21 October 2009 13:47 Go to previous messageGo to next message
Matthias,
1) I think you're asking about a "graph editor". We don't have that yet, but
it is an obvious addition. You can create your own graphs if you build STEM
from source. It involves creating and editing property files that define the
graphs and their components and then running an ant script which builds all of
the built-in graphs/models/scenarios from the properites files. Ask for more
information if you want to follow this path.
2) This is definitely something we've thought about, and need, but don't have.
One thing I was thinking was we should be able to do something with GEF or GMF
to create the graph visualizations from our EMF models, but I haven't had
enough time to get familiar enough to actually do anything.
Dan
Matthias Filter wrote:
> Hi all,
> Matthias
Re: STEM Milestone M2 is now Available!! [message #492825 is a reply to message #492794] Wed, 21 October 2009 17:47 Go to previous messageGo to next message
Dear Dan,
yes you were right, the thing I was looking for was a graph editor. A possibility to edit or modify preinstalled graphs could be quite useful especially for user that are not familiar with programming or that experience technical problems when following the developer instructions. So if it would be possible to implement that without to much effort it would be for sure a big plus.
Concerning the graph visualization tool: I can imagine that there are a lot of other tasks on the "wish" list. So maybe one could describe these higher level goals on the project plan website and by this further increase the support for the development team. I for myself have the possibility to invest some of my resources next year into this project and for planning this such information would be very helpful as well.
Matthias
Re: STEM Milestone M2 is now Available!! [message #495887 is a reply to message #492825] Fri, 06 November 2009 09:02 Go to previous messageGo to next message
Actually, I was thinking of more of a graphical "graph editor". STEM already
has an editor for graphs (and models and scenarios). It is tree based. If
you want you can copy one of the built-in graphs and paste them into a
project. Then open up the copy and you should be able to manipulate it in the
editor.
This is a good question. I don't think I could give that summary here, but
I'll mention it to the other committers and try to get some consensus on the
future goals recorded.
Dan
> Dear Dan,
big plus.
> Matthias
Re: STEM Milestone M2 is now Available!! [message #495919 is a reply to message #495887] Fri, 06 November 2009 11:04 Go to previous messageGo to next message
concerning the graph editior:
In my experience it is currently only partly possible to modify prebuild graphs. E.g. if I copy a prebuild graph for Germany into the existing "graph editor" (e.g. "DEU(1) population") I can modify the label of the nodes and save it, but I can not delete a node or generate a new one. As far as I understood this is currently only possible when one edit the property files and build STEM from source. So I think, in principle the available graph editor works fine and one has "only" to extend the functionalities.
Of course, in the longer perspective alternative graph editor concepts could also be considered, e.g. something like yEd (http://www.yworks.com/en/products_yed_about.html), but as I said the extension of the one available would be great as well.
concerning future goals:
I will put some additional ideas on this in the new thread: "STEM Plan for Version 2"
Matthias
Re: STEM Milestone M2 is now Available!! [message #501048 is a reply to message #491933] Mon, 30 November 2009 14:34 Go to previous messageGo to next message
I just spoke with Matthias and he hopes to join our call regularly in the
near future.
What he mentioned, is that the main Frontpage "eclipse.org/stem" is still a
bit outdated.
Which is true, it still says:
>Project Status
>June 14, 2009 - Stable v0.5.0 of STEM is available for download
>January 28'th, 2009 - v0.4.0 of STEM is available for download
>September 9'th, 2008 - v0.3.0a of STEM is available
Who can change that?
Werner
Re: STEM Milestone M2 is now Available!! [message #501336 is a reply to message #501048] Tue, 01 December 2009 16:38 Go to previous messageGo to next message
Hi Werner,
first of all thanks again for the opportunity to talk yesterday. Concerning the update of the website:
the same is true - to a somewhat lesser extend - to the wiki page:
http://wiki.eclipse.org/index.php/STEM
Regards, Matthias
Re: STEM Milestone M2 is now Available!! [message #561466 is a reply to message #491933] Tue, 20 October 2009 06:27 Go to previous messageGo to next message
Hi all,
Matthias
Re: STEM Milestone M2 is now Available!! [message #561484 is a reply to message #561466] Wed, 21 October 2009 13:47 Go to previous messageGo to next message
Matthias,
Dan
> Hi all,
> Matthias
Re: STEM Milestone M2 is now Available!! [message #561502 is a reply to message #492794] Wed, 21 October 2009 17:47 Go to previous messageGo to next message
Dear Dan,
Matthias
Re: STEM Milestone M2 is now Available!! [message #561623 is a reply to message #561502] Fri, 06 November 2009 09:02 Go to previous messageGo to next message
editor.
Dan
> Dear Dan,
big plus.
> Matthias
Re: STEM Milestone M2 is now Available!! [message #561662 is a reply to message #495887] Fri, 06 November 2009 11:04 Go to previous messageGo to next message
Matthias
Re: STEM Milestone M2 is now Available!! [message #561696 is a reply to message #491933] Mon, 30 November 2009 14:34 Go to previous messageGo to next message
near future.
bit outdated.
>Project Status
Werner
Re: STEM Milestone M2 is now Available!! [message #561716 is a reply to message #501048] Tue, 01 December 2009 16:38 Go to previous message
Hi Werner,
Regards, Matthias
Previous Topic:Re: MAPPING
Next Topic:STEM Community
Current Time: Sat Jul 19 11:33:03 EDT 2025
Powered by FUDForum. Page generated in 0.06054 seconds
