Home » Eclipse Projects » Virgo » Unable to debug OSGi modules on Virgo in Eclipse
Unable to debug OSGi modules on Virgo in Eclipse [message #560224] Tue, 21 September 2010 11:22 Go to next message
I am working on an application the spans multiple OSGi bundles. This works when running directly on Virgo Server. So the code is sound.
When I attempt to run the server in debug mode on Eclipse, the debug command seems to be ignored, and the server seems to start in normal run mode. Obviously this prevents me from doing step-by-step debugging.
Maven is being used to build the application.
I feel like I am missing something. What do I need to do to make debug mode work?
Thanks.
Re: Unable to debug OSGi modules on Virgo in Eclipse [message #560229 is a reply to message #560224] Tue, 21 September 2010 11:40 Go to previous messageGo to next message
Did you specify the -debug switch to the Virgo startup script? That should listen for the debugger to attach. If you want to prevent Virgo from starting until you have attached the debugger (and, for example, set a breakpoint), use both the -debug and -suspend switches.
Details are in the user guide.
(I am assuming you are happy to run Virgo externally to Eclipse and attach the Eclipse debugger to the Virgo process. If you are trying to run Virgo in debug mode using the Virgo tooling, e.g. in STS, then that's a different story.)
[Updated on: Tue, 21 September 2010 11:42] by Moderator
Re: Unable to debug OSGi modules on Virgo in Eclipse [message #562478 is a reply to message #560224] Tue, 21 September 2010 12:21 Go to previous messageGo to next message
Ideally I would like to be able to start and stop the server from within Eclipse.
STS has some dependency issues that I haven't worked out, so it won't install at this time.
But anything would be better than no debugging. How does one attach an external process to the Eclipse debugger?
Re: Unable to debug OSGi modules on Virgo in Eclipse [message #582070 is a reply to message #560229] Tue, 21 September 2010 13:38 Go to previous messageGo to next message
Ideally I would like to be able to start and stop the server from within Eclipse Helios.
Re: Unable to debug OSGi modules on Virgo in Eclipse [message #590347 is a reply to message #582070] Tue, 21 September 2010 14:07 Go to previous message
I found this url that explains how to connect a report instance to the Eclipse debugger:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg25 518.html
Previous Topic:R-OSGi over Virgo
Next Topic:Where do non-Virgo logs end up?
Current Time: Sun Jul 20 15:34:18 EDT 2025
Powered by FUDForum. Page generated in 0.04524 seconds
