Home » Eclipse Projects » Rich Client Platform (RCP) » Graphical library for fancy effects
Graphical library for fancy effects [message #559232] Thu, 16 September 2010 02:48 Go to next message
I don't know where to post this question precisely so I post it in the RCP forum (this is in some way related to RCP).
I am looking for a graphical library that can be used to enhance graphically an RCP application. Something similar to Draw2D but more targeted on fancy effects.
What I mean with "fancy effects" are things like antialiased fonts, transparent windows, easy to implement animations (like elements fading in/out), ...
So, in brief, everything that would help to make an RCP application visually appealing (typically, this would be done in a specific view).
Thanks.
Re: Graphical library for fancy effects [message #559306 is a reply to message #559232] Thu, 16 September 2010 06:36 Go to previous message
You can have a look at the advanced graphics provided by SWT. You can see the SWT Advanced graphics example which shows the graphics operations.
In the eclipse SDK, go to: Help -> Welcome. On the welcome page select Samples ->Workbench views and standalone applications. This will download and install the examples into the eclipse SDK. And let you run the examples and also view the source.
Previous Topic:eclipse workebench plugin start problem
Next Topic:Context menu in a wizard
Current Time: Sat Jul 19 05:52:53 EDT 2025
Powered by FUDForum. Page generated in 0.05515 seconds
