Home » Modeling » EMF » Emf->Xsd->Java code to serialize deserialize xml
Emf->Xsd->Java code to serialize deserialize xml [message #558980] Wed, 15 September 2010 04:40 Go to next message
the only thing i want to do is to read and write xml-files specified by a xsd-file. i tried jaxb but it ignores all restrictions in object space (no validation).
so i stumbled across emf. it seems to do - among other things Wink - exactly what i need.
in meanwhile i generated code from the xsd i need. but what now? At the end i want a minimum set of classes and dependencies to read and write xml files respecting the underlying xsd - and use them in a maven project. how to do this?
splitting it up in subquestions:
- how to use the generated code to read/write xml files?
- how to cut or generate an artifact out of the emf-eclipse-project to be used as "myxmlapi"(.jar with needed dependencies)
thx in advance
Re: Emf->Xsd->Java code to serialize deserialize xml [message #559214 is a reply to message #558980] Wed, 15 September 2010 22:36 Go to previous messageGo to next message
Comments below.
I'm not surprised. Restrictions are just not well expressed/represented
in Java or any other object oriented language (which focus on extension).
> so i stumbled across emf. it seems to do - among other things ;) -
If you invoke Generate Test Code you'll end up with a small example that
reads and writes instances.
If you run the generated XyzExample.java you'll get the idea. The XML
binding article on the documentation page is quite useful too.
> thx in advance
Re: Emf->Xsd->Java code to serialize deserialize xml [message #559245 is a reply to message #559214] Thu, 16 September 2010 03:33 Go to previous message
thx for the "generate test code" hint - very helpful
i'll examine it...
Previous Topic:Re: [cdo] streaming large data?
Next Topic:containment and emf treenode model
Current Time: Sun Jul 20 06:21:23 EDT 2025
Powered by FUDForum. Page generated in 0.04401 seconds
