Home » Modeling » TMF (Xtext) » Hyperlinks in Strings/Comments
Hyperlinks in Strings/Comments [message #558337] Sat, 11 September 2010 06:34 Go to next message
I have the need to provide hyperlinks in comments (as an example
recognize a URL in a comment and making it clickable).
Grateful if someone could suggest how to implement something like that.
- henrik
Re: Hyperlinks in Strings/Comments [message #558342 is a reply to message #558337] Sat, 11 September 2010 07:46 Go to previous messageGo to next message
there are a couple of threads in the forum dealing with similar problems, an approach is contained in the MWE2 grammar project.
One possibility is changing the grammar, making strings and comments not being single terminals but rather composed elements that can contain elements of type link. You'd still have to adapt the linking though. Also this would make the grammar quite complicated and if you don't want to use the comments or strings otherwise (just allow navigation for the user), this might be an overkill.
My first suggestion would be to implement your own HyperlinkHelper "extending" the createHyperlinkByOffset method. The difficult part will be (if you don't change the grammar for comments) "manually" parsing the comment node, checking whether there actually is a URL under the current cursor position. You can then create your own I/Abstract/XtextHyperlink associating whatever you want with the open-method.
Alex
Re: Hyperlinks in Strings/Comments [message #558607 is a reply to message #558342] Mon, 13 September 2010 12:08 Go to previous messageGo to next message
Splitting up the text into fine grained grammar opens up a very large
can of worms, and I was thinking of finding the links in the data type
conversion. I currently use a String for the documentation data, but
could just as well have a type that contains more information.
Or, is there some other place where it is convenient to introduce
"additional parsing" ? I can imagine computing offsets on demand and
storing in an adapter for instance.
- henrik
On 9/11/10 1:46 PM, Alexander Nittka wrote:
> Alex
Re: Hyperlinks in Strings/Comments [message #558655 is a reply to message #558607] Mon, 13 September 2010 16:01 Go to previous messageGo to next message
I fear I am the wrong one to ask for best practice. But my feeling is that if you "evaluate" the links in comments etc. only for user triggered navigation (F3), it may be an overkill to pre-calculate everything during parsing (or value conversion). It will suffice to check whether there is a hyperlink on demand in the said method.
Alex
Re: Hyperlinks in Strings/Comments [message #558662 is a reply to message #558337] Mon, 13 September 2010 16:07 Go to previous messageGo to next message
Am 9/11/10 12:34 PM, schrieb Henrik Lindberg:
> Regards
> - henrik
You could override the binding in
org.eclipse.xtext.ui.DefaultUiModule.bindIHyperlinkDetector( )
and add an implementation which delegates to
org.eclipse.jface.text.hyperlink.URLHyperlinkDetector
in addition to the default behavior.
Sven
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Hyperlinks in Strings/Comments [message #558759 is a reply to message #558342] Tue, 14 September 2010 07:08 Go to previous messageGo to next message
Alexander Nittka wrote on Sat, 11 September 2010 07:46
Alex
I think the cleanest solution (but probably overkill) would be to introduce a second grammar for parsing the comments. I guess that's how Javadoc etc. gets parsed.
It is pretty easy to call that parser on demand and it allows you to create syntax highlighting (just call it in your AntlrTokenToAttributeIdMapper), content proposal and all sorts of stuff.
Performance could suffer, though.
Re: Hyperlinks in Strings/Comments [message #558775 is a reply to message #558662] Tue, 14 September 2010 07:19 Go to previous message
Hi Sven, hi Henrik,
the URLHyperlinkeDetector is registered as well. The bound detector is
added to the default list of hyperlinke detectors in the
XtextSourceViewerConfiguration.
Sebastian
Am 13.09.10 22:07, schrieb Sven Efftinge:
>> Hi,
>> Regards
>> - henrik
> Sven
Previous Topic:Narrowing content assist choices
Next Topic:Problem with unordered groups
Current Time: Sat Jul 19 20:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.04121 seconds
