Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Calling MTL queries from java code
[Acceleo 3] Calling MTL queries from java code [message #558740] Tue, 14 September 2010 05:28 Go to next message
Hi Guys,
Is there some kind of helper similar to Xtend's XtendFacade which would
allow executing MTL queries defined in a MTL template file from Java
code ? Both standalone and under Eclipse.
Kind regards,
Cédric Vidal
Re: [Acceleo 3] Calling MTL queries from java code [message #558749 is a reply to message #558740] Tue, 14 September 2010 05:56 Go to previous messageGo to next message
--------------040509090200040502050303
Hi C
Re: [Acceleo 3] Calling MTL queries from java code [message #558827 is a reply to message #558740] Tue, 14 September 2010 10:25 Go to previous messageGo to next message
--------------000702050506080706060504
Hi Cedric,
copy/pasting the previous message as it seems the forum (
http://www.eclipse.org/forums/index.php?t=msg&th=175371& amp;start=0&S=65d6c539a6d9a8d86083c7deb9a9abb1
) doesn't support UTF-8 :p.
The planned API only allows for clients to call Acceleo Templates, not
Queries; though I believe you should be able to mimic it in order to
call queries as well. Take a look at AcceleoService#doGenerate to see
how it's done ... don't hesitate to raise enhancement requests on the
bugzilla is the API isn't opened enough for you to call queries instead
of Templates :) .
Laurent Goubet
Obeo
Cedric Vidal wrote:
> Hi Guys,
> Kind regards,
> C
Re: [Acceleo 3] Calling MTL queries from java code [message #559058 is a reply to message #558827] Wed, 15 September 2010 09:12 Go to previous messageGo to next message
Hi Laurent,
Thanx for your quick answer :)
I've had a look at AcceleoService and thanx to your explanation, I've
managed to execute a MTL query programmatically. Actually, it was pretty
easy as the syntax of MTL queries is actually directly parsed into OCL
Expressions and directly accessible in the MTL Ecore Metamodel.
So all I had to do was to mimic the doEvaluate method of AcceleoEngine
and transform the Query's OCL expression into an OCL Query and evaluate it.
But I had to fork AcceleoService and AcceleoEngine. The original code is
pretty dependent on the fact that files are being generated which is not
relevant when executing queries (and AcceleoService is a final class ;) ).
What's more, I have an issue with the cleaning up after execution. I
stopped there as I didn't have the time to investigate that problem.
Regarding the API, it would indead be great if Acceleo 3 supported that
use case. According to me, it's very important to be able to leverage
the set of MTL queries you've written into Java code. It allows creating
libraries of queries that you can reuse both in MTL templates and Java code.
Regarding how the API could look like, I guess the following additional
methods in AcceleoService could do the job (mine look alike):
public Object doQuery(Module module, String queryName, EObject model,
Monitor monitor);
public Object doQuery(Query query, EObject model, Monitor monitor);
Cédric Vidal
Le 14/09/2010 16:25, Laurent Goubet a écrit :
> Hi Cedric,
> of Templates :) .
> Laurent Goubet
> Obeo
> Cedric Vidal wrote:
>> Hi Guys,
>> would allow executing MTL queries defined in a MTL template file from
>> Java code ? Both standalone and under Eclipse.
>> Kind regards,
>> Cédric Vidal
Re: [Acceleo 3] Calling MTL queries from java code [message #559059 is a reply to message #559058] Wed, 15 September 2010 09:17 Go to previous messageGo to next message
--------------080203090906060309050204
Hi Cedric,
Thanks for the follow-up, could you raise an enhancement request on the
bugzilla with the code you wrote (as a patch or directly in the
comments) regarding these "doQuery" methods? That'll allow me to know
exactly the needed use case and quickly get the grasp of what changes
are needed :).
Laurent Goubet
Obeo
C
Re: [Acceleo 3] Calling MTL queries from java code [message #559078 is a reply to message #559059] Wed, 15 September 2010 10:04 Go to previous message
You're welcome. I'll submit a patch as soon as I get a chance. Probably
by friday. I'll keep you posted.
Le 15/09/2010 15:17, Laurent Goubet a écrit :
> Hi Cedric,
> are needed :).
> Laurent Goubet
> Obeo
> Cédric Vidal wrote:
>> Hi Laurent,
>> pretty easy as the syntax of MTL queries is actually directly parsed
>> into OCL Expressions and directly accessible in the MTL Ecore Metamodel.
>> evaluate it.
>> is pretty dependent on the fact that files are being generated which
>> is not relevant when executing queries (and AcceleoService is a final
>> class ;) ).
>> that use case. According to me, it's very important to be able to
>> leverage the set of MTL queries you've written into Java code. It
>> allows creating libraries of queries that you can reuse both in MTL
>> additional methods in AcceleoService could do the job (mine look alike):
>> Monitor monitor);
>> Best regards,
>> Cédric Vidal
>>> Hi Cedric,
>>> of Templates :) .
>>> Laurent Goubet
>>> Obeo
>>> Cedric Vidal wrote:
>>>> Hi Guys,
>>>> Kind regards,
>>>> Cédric Vidal
Previous Topic:Toolchain for source code generation from UML?
Next Topic:[xpand] problem calling xpand from Java
Current Time: Sun Jul 20 08:51:47 EDT 2025
Powered by FUDForum. Page generated in 0.24848 seconds
