Home » Modeling » Epsilon » Error when adding a model to a newly created launch configuration for an evl file
Error when adding a model to a newly created launch configuration for an evl file [message #558508] |
Mon, 13 September 2010 05:58  |
I've started using the latest interim release, and now I'm having
problems creating new launch configurations for evl files. The creation
itself works, but I cannot add any model file(s) without getting the
following error:
at
org.eclipse.epsilon.common.dt.launching.dialogs.ModelTypeSel ectionDialog.findModelTypes(ModelTypeSelectionDialog.java:17 9)
at
org.eclipse.epsilon.common.dt.launching.dialogs.ModelTypeSel ectionDialog.createDialogArea(ModelTypeSelectionDialog.java: 88)
at
org.eclipse.jface.dialogs.TitleAreaDialog.createContents(Tit leAreaDialog.java:155)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at
org.eclipse.epsilon.common.dt.launching.tabs.ModelsConfigura tionTab$AddModelListener.handleEvent(ModelsConfigurationTab. java:171)
It is possible to (duplicate and) edit an existing one, but this is only
a solution if you have one already.
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558591 is a reply to message #558568] |
Mon, 13 September 2010 11:37   |
Hi Hallvard,
Is this just a UI issue (given that EVL already supports access to
multiple models)?
Dimitris
Hallvard Trætteberg wrote:
> On 13.09.10 12.51, Dimitris Kolovos wrote:
>> Fixed in the interim site.
> It worked, thanks!
> My students are working on their first assignment, where they must use
> Emfatic and HUTN for creating a model and sample data, and eol/evl for
> constraints. They're very grateful for the quick response :-)
> A quick comment on creating launch configurations for evl files: I would
> guess the usual case is validating a single model. Hence, a slightly
> different design, where the source and model are chosen on the main tab,
> and the other tab used for adding additional models, would make sense.
> What do you think?
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593690 is a reply to message #558508] |
Mon, 13 September 2010 06:00  |
Thanks for reporting this. Looking at it now.
Dimitris
> following error:
> at
> at
> at
> at
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593701 is a reply to message #558509] |
Mon, 13 September 2010 06:33  |
I've reproduced this. Could you please file a bug report and I'll try to
fix this asap.
Dimitris
> Cheers,
> Dimitris
>> Hi,
>> creation itself works, but I cannot add any model file(s) without
>> getting the following error:
>> at
>> at
>> at
>> at
>> only a solution if you have one already.
>> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593727 is a reply to message #558519] |
Mon, 13 September 2010 06:51  |
Dimitris
> fix this asap.
> Cheers,
> Dimitris
>> Cheers,
>> Dimitris
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593793 is a reply to message #558520] |
Mon, 13 September 2010 09:53  |
It worked, thanks!
What do you think?
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593835 is a reply to message #558568] |
Hi Hallvard,
multiple models)?
Dimitris
> It worked, thanks!
> What do you think?
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593864 is a reply to message #558591] |
Mon, 13 September 2010 13:35  |
> multiple models)?
Yes, it's a simplification for the case where there is only one model,
based on the observation that my students find the current design a bit
confusing.
The existing Models tab can be kept as is, while the Source tab is
augmented (and renamed) with fields for setting/editing one (the first)
model, so the typical case becomes a bit simpler.
Hallvard
Current Time: Sat Jul 19 10:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.08584 seconds
