Home » Eclipse Projects » Rich Client Platform (RCP) » "No application id has been found." when I imported new dependency
"No application id has been found." when I imported new dependency [message #557861] Thu, 09 September 2010 05:18 Go to next message
Hello, everybody. I'm developing a RCP-based project. I decided to use JFace data-binding framework to build the GUI form stuff. Since that, I imported some neccessary packages to my project, such as
org.eclipse.core.databinding,
org.eclipse.core.databinding.observable,
org.eclipse.core.databinding.observable.list
etc.
All seem all right, but when I added this one to MANIFEST.MF:
org.eclipse.core.databinding.beans
my program failed to start, and the runtime exception info is:
[i]java.lang.RuntimeException: No application id has been found.
	at  org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
	at  org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
	at  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
	at  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
	at  org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
	at  org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
	at  org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)[/i]
What am I supposed to do in terms of this problem?
[Updated on: Thu, 09 September 2010 05:20] by Moderator
Re: "No application id has been found." when I imported new dependency [message #557874 is a reply to message #557861] Thu, 09 September 2010 06:04 Go to previous messageGo to next message
Fix your PDE-launch configuration and if you already have a
..product-Definition this one as well.
Tom
Am 09.09.10 11:18, schrieb Frank:
> etc.
> my program can run, and the runtime exception info is:
> tarter.java:369)
> tarter.java:179)
Re: "No application id has been found." when I imported new dependency [message #557929 is a reply to message #557874] Thu, 09 September 2010 09:28 Go to previous messageGo to next message
To clarify the last answer. You are missing plugins in your startup config. So open the start configuration for your product, click on the plugins tab and Click on Add Required Plugins.
Re: "No application id has been found." when I imported new dependency [message #558053 is a reply to message #557929] Thu, 09 September 2010 23:12 Go to previous message
Thank you all, I get it. Razz
Previous Topic:Opening an editor / view (SWT) without loading eclipse
Next Topic:for org.eclipse.ui.navigator.navigatorContent where/how are the "property" values defined?
Current Time: Sat Jul 19 05:54:38 EDT 2025
Powered by FUDForum. Page generated in 0.04265 seconds
