Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Calling service on list(Can you call a service on a list object in Acceleo 3?)
[Acceleo 3] Calling service on list [message #557193] Sun, 05 September 2010 20:15 Go to next message
In Acceleo 2 we used to be able to call a service on a list of objects and it would execute the service on each object in the list. When I try to call the following line in Acceleo 3:
eGenericSuperTypes.genSuperClassDeclaration(eClass.ePackage)
(genSuperClassDeclaration is a service that I wrote in Acceleo 2 and is now a template I'm trying to run in Acceleo 3) this call causes an error in the higher level template:
Evaluation failed with an exception: index=1, size=1
Is this not doable anymore?
Thanks for your help in advance
Re: [Acceleo 3] Calling service on list [message #557221 is a reply to message #557193] Mon, 06 September 2010 03:44 Go to previous messageGo to next message
--------------000301050701070206010405
Could you provide us with the whole stack trace? This should be working.
Laurent Goubet
Obeo
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000301050701070206010405--
Re: [Acceleo 3] Calling service on list [message #557286 is a reply to message #557221] Mon, 06 September 2010 09:10 Go to previous messageGo to next message
Thanks for the quick response. This is why we're investing so much in Acceleo. I really like what you guys are doing. Here is the full stack:
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBounds Exception: index=1, size=1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:3 52)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoQueryInvocation(AcceleoEvaluationVis itor.java:665)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoQueryInvocation(AcceleoEval uationVisitorDecorator.java:207)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoQueryInvocation(AcceleoTraceabil ityVisitor.java:406)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 498)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:91 2)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitExpression(AcceleoTraceabilityVisitor.j ava:524)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:781)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoTemplate(AcceleoEvaluationV isitorDecorator.java:218)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 465)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplateInvocation(AcceleoEvaluation Visitor.java:832)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoTemplateInvocation(AcceleoE valuationVisitorDecorator.java:229)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoTemplateInvocation(AcceleoTracea bilityVisitor.java:432)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 492)
at org.eclipse.ocl.internal.evaluation.IterationTemplate.evalua te(IterationTemplate.java:87)
at org.eclipse.ocl.EvaluationVisitorImpl.evaluateCollectIterato r(EvaluationVisitorImpl.java:1593)
at org.eclipse.ocl.EvaluationVisitorImpl.visitIteratorExp(Evalu ationVisitorImpl.java:1443)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitIteratorExp( EvaluationVisitorDecorator.java:241)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitIteratorExp(AcceleoTraceabilityVisitor. java:600)
at org.eclipse.ocl.ecore.impl.IteratorExpImpl.accept(IteratorEx pImpl.java:114)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab stractEvaluationVisitor.java:247)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E valuationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 517)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:473)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoIfBlock(AcceleoEvaluationVi sitorDecorator.java:163)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoIfBlock(AcceleoTraceabilityVisit or.java:374)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 471)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoFileBlock(AcceleoEvaluationVisitor.j ava:316)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoFileBlock(AcceleoEvaluation VisitorDecorator.java:143)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoFileBlock(AcceleoTraceabilityVis itor.java:335)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 485)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(Query Impl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvalua te(AcceleoEngine.java:265)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate (AcceleoEngine.java:130)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate Template(AcceleoService.java:544)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate (AcceleoService.java:389)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. generate(AbstractAcceleoGenerator.java:120)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. doGenerate(AbstractAcceleoGenerator.java:99)
at org.openjaus.mercury.ecore.gen.cpp.Main.doGenerate(Main.java :148)
at org.openjaus.mercury.ecore.gen.cpp.Main.main(Main.java:126)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchO peration.run(AcceleoLaunchOperation.java:105)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 220)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 123)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchD elegate.launch(AcceleoLaunchDelegate.java:53)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:923)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: [Acceleo 3] Calling service on list [message #557298 is a reply to message #557286] Mon, 06 September 2010 10:00 Go to previous messageGo to next message
--------------030208040406010400000901
Tom,
Okay, this is a known issue we're striving to fix. In a nutshell, you're
trying to call a query which demands two or more parameters with the
first being implicit. In Acceleo words you have a query :
[query public myQuery(x : Foo, y : Bar = ... /]
and you try to invoke it from somewhere like such :
[template public myTemplate(x : Foo, y : Bar)]
[myQuery(y)/]
[/template]
Which *should* work ... yet does not because of bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320474 . You can
workaround it by explicitely passing your elements :
[x.myQuery(y)/]
[myQuery(x, y)/]
[/template]
Laurent Goubet
Obeo
> index=1, size=1
> Visitor.java:832)
> pImpl.java:114)
> Visitor.java:832)
> Visitor.java:832)
> Impl.java:152)
> ssorImpl.java:57)
> gin.java:1126)
--------------030208040406010400000901--
Re: [Acceleo 3] Calling service on list [message #557343 is a reply to message #557298] Mon, 06 September 2010 21:52 Go to previous messageGo to next message
Laurent,
Thanks for the idea. I tried a few things based on your suggestion. I'm not sure if the problem I'm having is exactly the same bug...
The first thing I tried was to explicitly pass the first parameter:
genSuperClassDeclaration(eGenericSuperTypes, eClass.ePackage)
When I did this I got the compile error:
illegal operation signature: (genSuperClassDeclaration(OrderedSet(EGenericType), EPackage)
Which is true because my template is defined as:
[template public genSuperClassDeclaration(eGenericType : ecore::EGenericType, currentPackage : ecore::EPackage)]
Like I mentioned before, with Acceleo 2 I used to be able to call a script on a list of objects as well as a single object and the generator would automatically call the script multiple times (once for each object in the list). If I pass in the parameter now explicitly this doesn't make sense because the parameter type is not a list, but I'm passing in a list. Is this "list type" template calling no longer possible in Acceleo 3, or do you still support it?
After this, I tried to explicitly call the template in a for loop:
[for (eGenericSuperTypes)][genSuperClassDeclaration(eClass.ePacka ge)/][/for]
This seemed to take away the error, but still didn't seem to execute correctly. Now after this template is finished the generation exits out of the [file] call and I see the following error:
Caused by: org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBounds Exception: index=1, size=1
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.ja va:423)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoForBlock(AcceleoEvaluationV isitorDecorator.java:153)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoForBlock(AcceleoTraceabilityVisi tor.java:356)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 478)
... 13 more
Re: [Acceleo 3] Calling service on list [message #557344 is a reply to message #557343] Mon, 06 September 2010 22:22 Go to previous messageGo to next message
I did fix one issue... The genSuperClassDeclaration template was calling a query that calls invoke() on a java method I wrote. When I explicitly passed in the first argument of the query, things worked better, but now I'm having new issues I need to figure out. I'll post more on that soon...
I'm still curious about the list template calling. I thought that was a really nice feature of Acceleo 2. Any information about that would be much appreciated.
Tom G
Re: [Acceleo 3] Calling service on list [message #557376 is a reply to message #557344] Tue, 07 September 2010 04:02 Go to previous messageGo to next message
--------------020803010304050509010005
Hi Tom,
As mentionned, it should work in Acceleo 3, as we did everything in
order for it to work. Yet you are in a case we didn't think of : calling
a multiple parameters query with a list of things for the first, and a
single value for the second parameter.
In short, with a query defined as :
you should be able to call it with :
[x.myQuery(y)/]
[myQuery(x, y)/]
and thus, calling it from inside a loop on your list should work. The
other possibility is (with "sequence : Sequence(Foo)") :
[sequence.myQuery(y)/] <= automatically converted by OCL to
"sequence->collect(temp1 | temp1.myQuery(y))"
The possibility that fails because of the bug I mentionned earlier is :
[myQuery(y)/]
It will work in future versions. On the other hand, "myQuery(sequence,
y)" will never work.
Hope this clears out some of the confusion.
Laurent Goubet
Obeo
> much appreciated.
> Thanks
> Tom G
--------------020803010304050509010005--
Re: [Acceleo 3] Calling service on list [message #557387 is a reply to message #557193] Tue, 07 September 2010 05:04 Go to previous messageGo to next message
Hi Tom,
I was the one who created the entry on the bugzilla, but I didn't have the time to solve the problem at that moment. I checked the problem yesterday and this morning, and it should be solved for the next update of Acceleo 3.0 (SR1 in the end of september) and in Acceleo 3.1 next year.
http://a.imageshack.us/img840/720/implicitcall.png
Stephane Begaudeau, Obeo
Re: [Acceleo 3] Calling service on list [message #557447 is a reply to message #557387] Tue, 07 September 2010 09:19 Go to previous messageGo to next message
Great. Nice work. I'm looking forward to SR1.
Tom
Re: [Acceleo 3] Calling service on list [message #557524 is a reply to message #557447] Tue, 07 September 2010 19:50 Go to previous message
Also, Laurent, thank you. That description does clear up my questions.
Previous Topic:[Acceleo] Problem with String replaceAll
Next Topic:[Acceleo 3] Question about debugging templates
Current Time: Sat Jul 19 13:52:07 EDT 2025
Powered by FUDForum. Page generated in 0.06051 seconds
