Home » Modeling » GMF (Graphical Modeling Framework) » Custom Connection Anchors
Custom Connection Anchors [message #556675] Thu, 02 September 2010 05:55 Go to next message
Hi @ all,
does anybody know, how to implement the standard behavior of gmf-editors
in a way, that connections no longer "snap" to the rectangular container
of a node?
I tried to implement the two methods
getTargetConnectionAnchor(ConnectionEditPart arg0) and get
SourceConnectionAnchor(ConnectionEditPart arg0) plus the two methods for
the requests.
In these methods I returned an EllipseAnchor instead of the standard
chopbox Anchor...
These were the steps, I found here in the gmf-forums, but unfortunately
these methods are never called (the request methods are called).
Also, if I add the @Override tags to the methods, an message appears to
remove the tags ("The method
getTargetConnectionAnchor(ConnectionEditPart) of type CircleEditPart
must override or implement a supertype method")
If anybody knows how to change this behavior, please let me know ;)
Thanks a lot,
Masija
Re: Custom Connection Anchors [message #556742 is a reply to message #556675] Thu, 02 September 2010 09:53 Go to previous messageGo to next message
On 02-09-10 11:55, Masija wrote:
> Hi @ all,
> of a node?
This use case is actually described in the GMF book. (Yes there is one,
but it's in disguise!)
http://www.eclipse.org/resources/resource.php?id=493
(Page 94)
I have done it myself, but what it describes is overriding indeed those
two methods getSource/TargetConnectionAnchor(..) in your xxxEditPart.
rgds, Christophe
> the requests.
> chopbox Anchor...
> Thanks a lot,
> Masija
Re: Custom Connection Anchors [message #556802 is a reply to message #556742] Thu, 02 September 2010 12:30 Go to previous message
Okay i solved this problem...
For
public ConnectionAnchor getSourceConnectionAnchor(
ConnectionEditPart connEditPart) {
return new EllipseAnchor(this.getFigure());
i imported org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art instead of the correct org.eclipse.gef.ConnectionEditPart Embarrassed
Sorry for the dumb question, and thanks for your reply Wink
Masija
Previous Topic:eContainer in OCL Expression
Next Topic:One metamodel Two Diagrams
Current Time: Sun Jul 20 17:09:28 EDT 2025
Powered by FUDForum. Page generated in 0.02994 seconds
