Home » Eclipse Projects » SWTBot » Strategy to have SWTBot test cases working accross different windowing systems
Strategy to have SWTBot test cases working accross different windowing systems [message #556592] Wed, 01 September 2010 19:03 Go to next message
Originally posted by: manu_ny.optimum.net
We have some SWTBot test cases that work well on MacOSX. Once deployed
on a testing machine which happens to be a linux machine with TWM window
manager, suddenly all our test cases fail because it seems that new
shell(s) do not get the focus or the activation they should. Is the only
way to get the test cases to work across different windowing systems is
to force some calls to SWTBot "activate" method? No chance that such
internals be encapsulated in the library?
On a side note, we get such exception from SWTBot:
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundExcep tion: The w
idget was null.
at
org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.&lt ;init>(AbstractSWTBot.java:96)
at
org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBotControl. <init>(AbstractSWTBotControl.java:47)
at
org.eclipse.swtbot.swt.finder.widgets.SWTBotShell.<in it>(SWTBotShell.java:49)
at
org.eclipse.swtbot.swt.finder.widgets.SWTBotShell.<in it>(SWTBotShell.java:38)
at
org.eclipse.swtbot.swt.finder.SWTBotFactory.activeShell(SWTB otFactory.java:341)
at
org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:208)
at
org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:198)
Would it be possible to add a bit more context to some of SWT
exceptions? The widget was null is rather limited. For instance, just
adding the name of the shell the system is trying to access would be a
big help for debugging.
Thanks.
Emmanuel.
Re: Strategy to have SWTBot test cases working accross different windowing systems [message #556756 is a reply to message #556592] Thu, 02 September 2010 09:37 Go to previous message
> Thanks.
> Emmanuel.
There is. You only need to set-up log4j properly. There is a couple of
log4j.xml files across the repository which you could use as a start-off
point, but aside of that I can't really give you any other hints (I've
never activated it myself...)
Hope this helps
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Previous Topic:MultiPageEditor with Tabs(GEF Editor) and SWTBot
Next Topic:Issues with tree widget
Current Time: Sat Jul 19 17:10:55 EDT 2025
Powered by FUDForum. Page generated in 0.23497 seconds
