Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Can't get past preverifier compile error
Can't get past preverifier compile error [message #528608] Wed, 21 April 2010 05:16 Go to next message
I'm a newcomer to mobile development in general and MTJ in particular. I've read what documentation I can find, and I've successfully (I assume) installed the Nokia S60 SDK and MTJ into my Eclipse installation.
The problem I'm having is that I can't build my project because I can't get rid of this error:
"The project was not built since the device definition is incomplete. Cannot find the device preverifier no a default one. Fix device definition then try building this project."
I would have assumed that MTJ would pick up the preverifier in my S60 SDK like it picked up the executables Wink. No matter though, I found the device definition dialogue and put the path to the preverifier in my SDK bin directory in the box labelled "preverifier". Then I clicked ok and did cleaned the project. The error didn't go away. I went back to the dialogue and the preverifier had disappeared from the dialogue box.
So then I tried a couple of other things, these didn't help either:
- specifying a verifier.exe in the "default verifier" box
- putting the path to verifier2.exe in the verifier box - this value doesn't get cleared out, but it doesn't change the error message
I know I must be doing something pretty fundamental wrong because if no one could build their MTJ projects there would be something in the bug database about it.
Any clue as to what mistake I might have made?
Thanks for your help,
Ben
Re: Can't get past preverifier compile error [message #529459 is a reply to message #528608] Sun, 25 April 2010 16:18 Go to previous messageGo to next message
Bad news is I still can't get this MTJ to work.
The good news is that I found the pyx4me j2me-maven-plugin which works nicely. I thoroughly recommend it to anyone who's familiar with Maven and can't get MTJ to work.
http://pyx4me.com/pyx4me-maven-plugins/j2me-maven-plugin/int roduction.html
I'd still be interested in any pointers as to how to get MTJ working, but in the mean time I have a solution. Smile
Ben
Re: Can't get past preverifier compile error [message #529830 is a reply to message #529459] Tue, 27 April 2010 07:17 Go to previous messageGo to next message
Originally posted by: krischik.users.sourceforge.net
Am 25.04.2010, 22:18 Uhr, schrieb Ben Arnold <ben.arnold.spam@hotmail.com>:
Me too :-(.
You are not the first to suggest Maven over MTJ ;-). See
http://www.eclipse.org/forums/index.php?t=msg&goto=51670 0&
Martin
Martin Krischik
Re: Can't get past preverifier compile error [message #529838 is a reply to message #529459] Tue, 27 April 2010 08:46 Go to previous messageGo to next message
there is an issue with Eclipse and some Nokia Series 60 SDKs. you can check them on the forum nokia that they have more information about it. currentl as far as i remeber the only solution to have a good integrated environment with those nokia sdks is to use netbeans 6.5. but i encourage you to verify that information at the forum nokia web site
Smile
gep
Re: Can't get past preverifier compile error [message #555903 is a reply to message #529838] Mon, 30 August 2010 03:36 Go to previous messageGo to next message
I have exactly the same problem here on my PowerBook G4. I don't want to install maven for midlet development.
I also tried to use proguard from MacPorts and define it as default preverifier, but still no success. I use microemulator 2.0.4 as the device emulator.
I also tried to use mpowerplayer. But i don't know how to tell eclipse to use mpowerplayer as emulator.
Re: Can't get past preverifier compile error [message #557037 is a reply to message #528608] Fri, 03 September 2010 13:05 Go to previous message
This is not related to any SDKs. It was reported earlier https://bugs.eclipse.org/bugs/show_bug.cgi?id=312045
There was a bug on the code related to preverifier preferences. It is fixed and released to next MTJ 1.1.1service release.
You can get the very latest MTJ releases from http://www.eclipse.org/dsdp/mtj/download/downloads.php
Gorkem
Previous Topic:Is this Newsgroup dead?
Next Topic:Can't get past preverifier compile error
Current Time: Sat Jul 19 10:40:09 EDT 2025
Powered by FUDForum. Page generated in 0.29304 seconds
