Home » Modeling » EMF » Setting a "local ID" for objects
Setting a "local ID" for objects [message #554405] Sun, 22 August 2010 16:24 Go to next message
I need to implement the creation of a kind of "local object ID". The
requirements are:
- Somewhere in my object tree, I've got a sub-model (DataModel) that may
contain DataFields (abstract class). A DataField is either a
SimpleDataField (e. g. a String) or a TableDataField. A TableDataField may
again contain DataFields. Consequently, every SimpleDataField is
contained inside a DataModel, either directly or indirectly via a
TableDataField.
- Every DataField (both TableDataFields and SimpleDataFields) need to carry
an ID. The ID must an integer value less than 10.000 (*sigh*) and should be
generated starting from 1 without gaps. It must be unique within the
DataModel. The ID may not change when saving and reloading the
DataModel. It may not change if the DataField is moved inside the DataModel
(i. e, the order of fields is changed). It may not change if a DataField is
cut from the DataModel into the Clipboard and pasted back into the same
model. However, it has to be changed to a new ID if the DataField is pasted
into a different DataModel or pasted as an additional copy into the same
DataModel.
I am unsure about the way to implement this. I can easily have the DataModel
check for the highest ID present and return the next free ID, but I'm not sure
about where to set the ID. Up to now, I've used eInverseAdd, but during the
update to Helios, I realized that I was relying on an EMF weakness there that
apparently has been fixed. (My old meta-model had an opposite relationship to
the containment of DataModel --> DataField as well as a containment
TableDataField --> DataField - this never did work correctly, but nobody
noticed until now :-)).
I'm thinking about
- adding a secondary field to the DataField so that it is able to "remember"
the DataModel it originally belonged to
- having the DataModel watch out for inserted DataFields into either its own
containment feature or the TableDataFields, check for the "original"
DataModel and re-set the ID if necessary.
Do you think I'm on the right track? Also, I'm unsure on how to prevent the
DataModel from setting new IDs while the model is being loaded. Do you have
any suggestions there?
Thanks in advance
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
141 Reasons why you can't find your system administrator: 111. Trying to
*avoid* being in a meeting
Re: Setting a "local ID" for objects [message #554408 is a reply to message #554405] Sun, 22 August 2010 16:39 Go to previous messageGo to next message
Volker,
You've modeled this as an EAttribute with isID true? Do you need the
model to do these things for you or is it sufficient that it happens
when editing? Certainly things like createAddCommand could be
specialized to set an ID that's computed from the context. The
InitializeCopy command could avoid copying the ID... Deserialization
should only set the ID exactly as it was serialized; isn't that what
you're wanting?
Volker Wegert wrote:
> Hello,
> requirements are:
> TableDataField.
> DataModel.
> I'm thinking about
> Thanks in advance
> Volker
Re: Setting a "local ID" for objects [message #555200 is a reply to message #554408] Wed, 25 August 2010 15:25 Go to previous messageGo to next message
Ed,
answers below.
Ed Merks <Ed.Merks@gmail.com> writes:
Not yet, no. AFAIR I didn't do this because the ID is only unique for all
DataFields and subclasses within the model. Instances of other classes might
have other ID fields with the same values.
> Do you need the model to do these things for you or is it sufficient that it
> happens when editing?
That would be enough.
> Certainly things like createAddCommand could be specialized to set an ID
I've been trying to find this - it looks like a method of the ItemProvider,
but the only reference I could find was in help.eclipse.org/help33 - that
would be a bit outdated.
> The InitializeCopy command could avoid copying the ID...
From what I can see, that is instantiated by the CopyCommand, so I'd have to
override that, too - or did I moss something?
> Deserialization should only set the ID exactly as it was
> serialized; isn't that what you're wanting?
Exactly - if I move the ID generation out of the model classes, I won't have
to deal with this any longer.
Cheers
Volker
"You need the computing power of a Pentium, 16 MB RAM and 1 GB Harddisk to run
Win95. It took the computing power of 3 Commodore 64 to fly to the
Moon. Something is wrong here, and it wasn't the Apollo."
Re: Setting a "local ID" for objects [message #555227 is a reply to message #555200] Wed, 25 August 2010 19:06 Go to previous messageGo to next message
--------------060809050002070103090200
Volker,
Comments below.
> Ed,
> answers below.
It's in every version of the Javadoc which is available from the
documentation page for all the EMF versions.
The item provider is a factory for all the different commands, so you
can override creation there. You should set breakpoints and watch how
things work...
> Cheers
> Volker
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Volker,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:84k4nelckx.fsf@zak.home.volker-wegert.de"
type="cite">
<pre wrap="">Ed,
answers below.
Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> writes:
</pre>
<blockquote type="cite">
<pre wrap="">You've modeled this as an EAttribute with isID true?
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">Do you need the model to do these things for you or is it sufficient that it
</pre>
</blockquote>
</pre>
<pre wrap="">Certainly things like createAddCommand could be specialized to set an ID
</pre>
</blockquote>
</pre>
</blockquote>
documentation page for all the EMF versions.<br>
type="cite">
<pre wrap="">
</pre>
<pre wrap="">The InitializeCopy command could avoid copying the ID...
</pre>
</blockquote>
</pre>
</blockquote>
can override creation there.&nbsp; You should set breakpoints and watch how
things work...<br>
type="cite">
<pre wrap="">
</pre>
<pre wrap="">Deserialization should only set the ID exactly as it was
</pre>
</blockquote>
Cheers
Volker
</pre>
</blockquote>
</body>
</html>
--------------060809050002070103090200--
Re: Setting a "local ID" for objects [message #555792 is a reply to message #555227] Sat, 28 August 2010 16:19 Go to previous messageGo to next message
> It's in every version of the Javadoc which is available from the documentation
OK, found it, and it's working now - thanks for the pointer.
> The item provider is a factory for all the different commands, so you can
> override creation there. You should set breakpoints and watch how things
> work...
Thanks again, I think I understand things a little better now. I still have
one question related to the handling of copying and pasting objects. From what
I can see, the InitializeCopyCommand is used to copy the attributes and
references when copying an object from the model into the
clipboard. Naturally, this operation cannot copy the container
reference. Unfortunately, I need to know the container the original model
object was or is contained in when pasting an object. The reason for this is:
When cutting and pasting an object from/to the same container once, the ID may
not change. When pasting the object for a second time or if the object was
copied instead of cut, the ID has to be regenerated. When pasting the object
to a different container, the ID has to be changed. In other words: If the
source container is identical to the target container and the target container
still contains the original object, I need to regenerate the ID.
This means I can only decide whether I need to regenerate the ID when pasting
the object, and I need to have some details about the original object to do
so. I haven't found a way to carry this information from the
InitializeCopyCommand to the PasteFromClipboardCommand - is there any?
Volker
"INTEL inside" - The world's most widely used warning label.
Re: Setting a "local ID" for objects [message #555816 is a reply to message #555792] Sun, 29 August 2010 00:39 Go to previous messageGo to next message
--------------020003070101090802080000
Volker,
Comments below.
>> work...
> clipboard.
Yes.
> reference.
No, because the container would have to refer back to the contained
thing, which would modify it, and copying should not modify existing
objects.
Perhaps related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=157074
> not change.
On could argue that cut and paste isn't the same as cut and undo...
When pasting after a cut, the existing ID wouldn't conflict with any ID
existing in the tree...
So it sounds like you should update the ID during the add, rather than
during the copy creation....
> so.
None of the conditions you spelled out sounded like you should need to
know something about the original object. It sounds more like if you
copied the ID and then when you pasted it you changed it to be unique if
it conflicted, you'd be fine.
Nothing jumps to mind, no...
> Thanks
> Volker
<html>
<head>
</head>
Volker,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:84pqx232yk.fsf@zak.home.volker-wegert.de"
type="cite">
<pre wrap="">Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> writes:
</pre>
<pre wrap="">Volker Wegert wrote:
</pre>
</pre>
</pre>
</blockquote>
<pre wrap="">I've been trying to find this - it looks like a method of the ItemProvider,
</pre>
</blockquote>
<pre wrap="">It's in every version of the Javadoc which is available from the documentation
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">From what I can see, that is instantiated by the CopyCommand, so I'd have to
</pre>
</blockquote>
<pre wrap="">The item provider is a factory for all the different commands, so you can
work...
</pre>
</blockquote>
clipboard. </pre>
</blockquote>
Yes.<br>
type="cite">
<pre wrap="">Naturally, this operation cannot copy the container
reference.</pre>
</blockquote>
objects.<br>
type="cite">
<pre wrap=""> Unfortunately, I need to know the container the original model
object was or is contained in when pasting an object. </pre>
</blockquote>
Perhaps related to <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=157074">https://bugs.eclipse.org/bugs/show_bug.cgi?id=157074</a><br>
type="cite">
<pre wrap="">The reason for this is:
not change.</pre>
</blockquote>
On could argue that cut and paste isn't the same as cut and undo...<br>
type="cite">
<pre wrap=""> When pasting the object for a second time or if the object was
copied instead of cut, the ID has to be regenerated. </pre>
</blockquote>
existing in the tree...<br>
type="cite">
</pre>
</blockquote>
during the copy creation....<br>
type="cite">
<pre wrap="">
so. </pre>
</blockquote>
know something about the original object.&nbsp; It sounds more like if you
if it conflicted, you'd be fine.<br>
type="cite">
<pre wrap="">I haven't found a way to carry this information from the
</pre>
</blockquote>
Nothing jumps to mind, no...<br>
type="cite">
<pre wrap="">
Volker
</pre>
</blockquote>
</body>
</html>
--------------020003070101090802080000--
Re: Setting a "local ID" for objects [message #555870 is a reply to message #555816] Sun, 29 August 2010 16:08 Go to previous message
Ed,
Comments below.
Definitely, thanks for the link. I've CCed myself to this bug.
>> The reason for this is: When cutting and pasting an object from/to the same
>> container once, the ID may not change.
One could also argue that rearranging the order of elements should always
yield the same result, no matter how it was performed. Moving the objects
around with drag&drop operations does not change the IDs. Cutting objects and
pasting them at a different location within the same model should not change
the IDs either.
When pasting for the first time, that's true - but you can cut once and paste
multiple times...
Perhaps I should explain the background a bit: The ID is used to generate
database structures in a legacy system. If cutting and copying the field
generates a new ID, the database table will get a new field and the old
contents won't be accessible any longer.
> So it sounds like you should update the ID during the add, rather than during
Yes, definitely.
>> so.
> None of the conditions you spelled out sounded like you should need to know
> something about the original object. It sounds more like if you copied the ID
> and then when you pasted it you changed it to be unique if it conflicted,
> you'd be fine.
Not really, it's more like "copy the ID, and when pasting it, under certain
very specific conditions, keep it, otherwise regenerate it".
I've rigged something now - generating transient GUIDs before the copy,
copying the container's ID into the contained object and comparing the GUIDs
during pasting. Rather kludgy, but it works for the moment...
Thanks for the help
Volker
"And yes, to me, headless does mean no video. But in my case it also means no
keyboard/mouse. Is that headless-armless-legless?" (unknown)
Previous Topic:[CDO]Rerences
Next Topic:[CDO] How to fix inconsistent states of CDOObjects?
Current Time: Sat Jul 19 13:47:49 EDT 2025
Powered by FUDForum. Page generated in 0.08248 seconds
