Home » Eclipse Projects » Remote Application Platform (RAP) » Custom widget question
Custom widget question [message #555325] |
Thu, 26 August 2010 06:21  |
I'm developing a custom widget and I'm trying to figure out the best way to achieve my goal. Currently I tried to be tight with SWT best practices, so my custom widget - that is a Text - is wrapped in a Composite instead of directly extending Text:
public class Real extends Composite {
private Control control;
public Real(Composite parent, int style) {
super(parent, style);
createControl();
private void createControl() {
Text text = new Text(this, SWT.BORDER);
this.setControl(text);
public void setControl(Control control) {
this.control = control;
public Control getControl() {
return control;
Constructing the custom widget using pure SWT composition should be enough in most cases, since normally one would let RAP do all the stuff, but I have the requirement to handle particular behaviour of this widget client side, so I implemented the necessary javascript and life cycle adapter. And here comes the problem: client-side, the widget should be aware of the "control" property, therefore in the LCA i added the following code:
public class RealLCA extends AbstractWidgetLCA {
public void renderInitialization(Widget widget) throws IOException {
Real real = (Real) widget;
JSWriter writer = JSWriter.getWriterFor(real);
Control control = real.getControl();
WidgetAdapter adapter = (WidgetAdapter) WidgetUtil.getAdapter(control);
writer.newWidget(Real.class.getName(), new Object[] { adapter.getId() });
writer.set("control", "control", control);
ControlLCAUtil.writeStyleFlags(real);
The problem is that at this time control has not been created yet (Text LCA will be called after my LCA), so the result is an error:
Error in property control of class com.test.rap.ui.widgets.Real in method setControl with incoming value 'undefined': Undefined value is not allowed!
As a solution for this issue, I called Text LCA's "renderInitialization()" programmatically from my LCA, after "newWidget()" call:
AbstractWidgetLCA lca = WidgetUtil.getLCA(control);
lca.renderInitialization(control);
adapter.setInitialized(true);
This seems to work properly, the writer correctly set "control" property. The only drawback is that I have to call WidgetAdapter.setInitialized(true) to avoid the generation of another "newWidget" for Text that will override the existing one in the WidgetManager, but WidgetAdapter is internal API and generally I prefer to avoid using internals.
I would ask if this is a suitable solution or there are other ways to achieve this requirement.
Massimo.
Re: Custom widget question [message #555332 is a reply to message #555325] |
Thu, 26 August 2010 06:56   |
Hi Massimo,
one idea that comes to my mind is to set the control Id instead of
control itself. Something like this:
IWidgetAdapter adapter = WidgetUtil.getAdapter(control);
writer.set("controlId", "controlId", adapter.getId());
The interface IWidgetAdapter is not internal.
When you need the instance of the control in the JavaScript.... get it
by WidgetManager.findWidgetById( id ).
HTH,
Ivan
On 08/26/2010 1:21 PM, Massimo Zugno wrote:
> createControl();
> return control;
> @Override
> adapter.getId() });
> not allowed!
> "newWidget()" call:
> @Override
> adapter.getId() });
> Massimo.
Re: Custom widget question [message #555639 is a reply to message #555332] |
Fri, 27 August 2010 09:17   |
Hi Ivan,
thank you for your suggestion. Following your hint I managed to solve my issue moving the relevant part of the code at JavaScript side, although mantaining the Parent/Child containment at Java-side (to be SWT compliant). To solve the "timing" problem of the Control being created after parent container's creation, I added its initialization in an "appear" event:
// LCA
writer.newWidget(QX_TYPE, new Object[] { controlId });
// JavaScript
qx.Class.define( "com.test.rap.ui.widgets.Real", {
extend : qx.ui.layout.CanvasLayout,
construct : function() {
this.base(arguments);
this._controlId = arguments[0];
this.addEventListener("appear", this._onAppear);
properties : {
control : {
nullable : true,
init : "",
apply : "_applyControl"
members : {
_applyControl : function(){
var c = this.getControl();
c.addEventListener("blur", this._onBlur, this);
_onAppear : function(){
var wm = org.eclipse.swt.WidgetManager.getInstance();
var control = wm.findWidgetById(this._controlId);
this.setControl(control);
_onBlur : function(e){
Is this the correct way to proceed?
Another approach would be adding a plain qooxdoo TextField control directly in the constructor of my custom widget, but without coding it Java-side (I noticed this approach in other rap widgets like org.eclipse.swt.Combo where the widget is built with composition of pure qooxdoo components), but I don't like this idea very much.
Thank you,
Massimo.
Re: Custom widget question [message #555652 is a reply to message #555639] |
Fri, 27 August 2010 09:30   |
Hi Massimo,
it's great that you managed to solve the problem. Your code looks good
to me too.
Best,
Ivan
On 08/27/2010 4:17 PM, Massimo Zugno wrote:
> Hi Ivan,
> // LCA
> // JavaScript
> properties : {
> control : {
> nullable : true,
> init : "",
> members : {
> Thank you,
> Massimo.
Re: Custom widget question [message #557956 is a reply to message #555652] |
Thu, 09 September 2010 11:24   |
Unfortunately I have to revive this thread, since the "onAppear" solution seems to lead to other problems. After some research I noticed the class CoolItemLCA, that seems to fit exactly my scenario: a CoolItem child control is rendered after its parent which has a reference to it, and the solution is provided in the writeControl method:
private static void writeControl( final CoolItem coolItem ) throws IOException {
Control control = coolItem.getControl();
if( WidgetLCAUtil.hasChanged( coolItem, PROP_CONTROL, control, null ) ) {
final JSWriter writer = JSWriter.getWriterFor( coolItem );
final Object[] args = new Object[] { control };
if( control != null ) {
// defer call since controls are rendered after items
= ( WidgetAdapter )WidgetUtil.getAdapter( control );
adapter.setRenderRunnable( new IRenderRunnable() {
public void afterRender() throws IOException {
writer.call( SET_CONTROL, args );
} else {
However, the code references two internal classes: org.eclipse.swt.internal.widgets.WidgetAdapter and org.eclipse.rwt.internal.lifecycle.IRenderRunnable. I'm wondering if I can insert a change request in RAP's bugzilla, asking for these classes being exposed in the public RAP api. I think this will make sense since that WidgetAdapter methods and IRenderRunnable itself can be very useful in many scenarios.
Please let me know your opinions/suggestions...
Thans, massimo.
Re: Custom widget question [message #557984 is a reply to message #557956] |
Thu, 09 September 2010 12:40   |
Hi Massimo,
maybe you can achieve the same defer render with phase listener. See
this snippet:
final Button button = new Button( parent, SWT.PUSH );
button.setText( "This is button initial text!" );
RWT.getLifeCycle().addPhaseListener( new PhaseListener() {
private static final long serialVersionUID = 1L;
public void beforePhase( final PhaseEvent event ) {
// do nothing
public void afterPhase( final PhaseEvent event ) {
JSWriter writer = JSWriter.getWriterFor( button );
try {
writer.set( "text", "New button text" );
} catch( IOException e ) {
} finally {
RWT.getLifeCycle().removePhaseListener( this );
public PhaseId getPhaseId() {
return PhaseId.RENDER;
HTH,
Ivan
> IOException {
> WidgetAdapter adapter = ( WidgetAdapter
> } else {
> Thans, massimo.
Re: Custom widget question [message #558142 is a reply to message #558110] |
Fri, 10 September 2010 06:22  |
Hi Massimo,
please file an enhancement request with a description of your problem.
We will consider your request, but I can't promise anything.
Best,
Ivan
On 09/10/2010 11:36 AM, Massimo Zugno wrote:
> Hi Ivan,
> I tried your solution and that worked fine, except for the fact that
> the PhaseListener is "global", so the RENDER phase is fired only after
> the whole page is rendered, while IRenderRunnable is fired immediately
> after widget's creation. Using PhaseListener can cause problems if
> another widget, after control parent initialization but before RENDER
> phase is fired, try to retrieve the control...
> Will a change request for making WidgetAdapter/IRenderRunnable public
> API be considered? That would be useful in many scenarios.
> Massimo.
Current Time: Sat Jul 19 20:43:22 EDT 2025
Powered by FUDForum. Page generated in 0.47149 seconds
