Home » Eclipse Projects » Remote Application Platform (RAP) » Custom Table Paint
Custom Table Paint [message #555166] Wed, 25 August 2010 12:49 Go to next message
I am looking for how to draw a image. Well, drawing a image in cell is ok. But the image's size is reduced. I think this is because of SWT's behaviour and this will happen in SWT as well.
But, I can draw image size freely using SWT.PaintItem or SWT.MeasureItem event in SWT.
How about RAP? Is it possible to solve this problem?
Thanks in advance.
Myoungki
Re: Custom Table Paint [message #555338 is a reply to message #555166] Thu, 26 August 2010 07:31 Go to previous message
Hi Kim,
SWT.PaintItem or SWT.MeasureItem events are not supported in RAP. We are
trying to make the RWT functionality as close as possible to SWT.
The space for the image is calculated only first time when you set an
image on TableItem. If you try to set a bigger image again (even on a
different table item), the reserved space for it will not change. To
workaround this, you have to clear the Table by calling Table#clearAll()
and set all items data (text, images, colors...) again.
HTH,
Ivan
On 08/25/2010 7:49 PM, Kim Myoungki wrote:
> Hello,
> Thanks in advance.
> Myoungki
Previous Topic:Shell activate order problem
Next Topic:The tableViewer select the wrong row when invoke tableViewer.remove(obj)
Current Time: Sat Jul 19 09:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.04210 seconds
