Re: Code generation like Domain Model? [message #555648 is a reply to message #555646] |
Fri, 27 August 2010 09:47  |
> In the meantime i tried to do some experiments with the domain model. If
> one used the rule ENTITY every thing works fine, but not so for IMPORT.
IEObjectDescriptions are only generated for exported elements. By
default this means model elements that have a name (you can reference
only things that have a name). You can adapt this standard behaviour,
though (adding or removin elements from the exported ones and also
influencing the names they are given).
This explainy why not all types can be found.
Alex
P.S.: you will have the same "problem" with the Reader component for
mwe2 workflows as discussed in several threads already.
FUDForum. Page generated in 0.05151 seconds
