Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Forcr UI update
Forcr UI update [message #554846] Tue, 24 August 2010 10:18 Go to next message
is there some way to progrmmatically ensure all UI updates are performed?
Situation is:
I have a long computation done asynchronously in a Job.
Job updates a progressMonitor.
At Job termination I need to transfer a long (>700k)String to a Text
widget (txtWid.setText(hugeString)).
This operation, on the very first time, takes a long time (>10s.),
second iteration is much faster (<2s.)
The update is done via syncExec().
During this period the UI is freezed (normal!)
Problem is the progress monitor "lags behind" at the moment of the
freeze (it should be at 90%, but fisually is at 30%)
I thus suspect the UI updates are cached somehow and the single
wid.setText() blocks everything.
This is the code I'm using:
final Book book = (Book) o;
final Job job = new Job("Assemble") {
protected IStatus run(final IProgressMonitor monitor) {
final SubMonitor progress = SubMonitor.convert(monitor, 100);
progress.setTaskName("Assemble LaTeX");
IStatus status = assemble(book, progress.newChild(80));
progress.subTask("Save");
if (status.isOK()) {
// vvvv Tried to force update vvvv
try {
Thread.sleep(2000);
} catch (InterruptedException e) {}
// ^^^^ Tried to force update ^^^^
Display.getDefault().syncExec(new Runnable() {
public void run() {
if (tset != null) {
tset.setBookTitle(title);
tset.setLaTeX(tex); // << here is wid.setText(tex)
ready = true;
} else {
public void run() {
MessageDialog.openError(shell, "Unable to Assemble",
"Assemble error");
ready = false;
progress.worked(20);
return status;
job.setUser(true);
job.schedule();
Notice the part:
try {
Thread.sleep(2000);
This seems absolutely necessary to have the progress monitor behave
correctly.
In order to avoid a fixed amount of time I tried the following (and
several other variations), but it doesn't work;
public void run() {
Display.getCurrent().update();
book.notify();
try {
book.wait(); // << line 111
this rises an error:
java.lang.IllegalMonitorStateException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:485)
at
it.condarelli.writer.commands.AssembleLaTeX$1.run(AssembleLa TeX.java:111)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Other combinations simply do not work.
Can someone please tell me what is the Right Way (TM) to ensure UI is
fully updated before doing something this long?
Sub-question:
Is it normal there's this long delay the first time I fill a Text widget
with a lot of stuff?
I thought it might be due to some class loading or repeated need to
enlarge the underlying text structures (I don't know which).
If so: is there some way to "preallocate"?
One second delay (on a fast computer!) is acceptable, 10s+ isn't.
Thanks in advance.
Mauro
Re: Forcr UI update [message #554903 is a reply to message #554846] Tue, 24 August 2010 12:35 Go to previous messageGo to next message
Hi Mauro,
You may try this :
* Wait the end of the asynchronous calls waiting in UI thread.
public static void synchronizationWithUIThread() {
while (PlatformUI.getWorkbench().getDisplay().readAndDispatch()) {
// Do nothing, just wait
Mariot
Mauro Condarelli a écrit :
> Situation is:
> @Override
> try {
> Thread.sleep(2000);
> public void run() {
> if (tset != null) {
> ready = true;
> } else {
> public void run() {
> "Assemble error");
> ready = false;
> return status;
> job.setUser(true);
> job.schedule();
> Notice the part:
> try {
> Thread.sleep(2000);
> correctly.
> public void run() {
> book.notify();
> try {
> at
> Sub-question:
> Thanks in advance.
> Mauro
Re: Forcr UI update [message #554909 is a reply to message #554903] Tue, 24 August 2010 13:01 Go to previous messageGo to next message
Il 24/08/2010 18:35, Mariot Chauvin ha scritto:
> Hi Mauro,
> You may try this :
> Regards,
It doesn't work.
If I call it from my job I get:
!ENTRY org.eclipse.core.jobs 4 2 2010-08-24 18:51:06.641
!MESSAGE An internal error occurred during: "Assemble".
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Display.error(Display.java:1249)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:755 )
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3646)
at
it.condarelli.writer.commands.AssembleLaTeX$1.run(AssembleLa TeX.java:118)
which is reasonable, if I call it from the UI thread (via syncExec) it
simply does nothing, which, again, is reasonable since the loop is
executed exactly zero times.
OTOH a delay of about 600ms seems necessary to complete all painting.
Does SWT do some background painting?
readAndDispatch() seems to just queue operations and not actually
performing them.
Is this possible?
Mauro
> Mariot
>> Hi,
>> Situation is:
>> @Override
>> try {
>> Thread.sleep(2000);
>> public void run() {
>> if (tset != null) {
>> tset.setLaTeX(tex); //<< here is wid.setText(tex)
>> ready = true;
>> } else {
>> public void run() {
>> "Assemble error");
>> ready = false;
>> return status;
>> job.setUser(true);
>> job.schedule();
>> Notice the part:
>> try {
>> Thread.sleep(2000);
>> correctly.
>> public void run() {
>> book.notify();
>> try {
>> book.wait(); //<< line 111
>> at
>> Sub-question:
>> Thanks in advance.
>> Mauro
Re: Forcr UI update [message #555053 is a reply to message #554909] Wed, 25 August 2010 06:11 Go to previous message
modify the code to
Display.getDefault().sysncExec(new Runnable(){
while (Display.getDefault().readAndDispatch()) {
but i doubt this will solve your hanging problem on settext method,
for that may be you have to innovate...
may be use text.append method by breaking your text into small peaces
and providing a UI feedback that the text control is being loaded by GC or by a animated giff lable near your text control
all this can be done in a asyncExec which after each append or after n no of append calls ,
call Dispaly.getDefault().readAndDispatch();
for example
package winctr;
import java.io.BufferedReader;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileReader;
import java.io.IOException;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.SWT;
public class NewComposite extends org.eclipse.swt.widgets.Composite {
	private Text text1;
	private Text text2;
		showGUI();
	public static void showGUI() {
		Display display = Display.getDefault();
		Shell shell = new Shell(display);
		NewComposite inst = new NewComposite(shell, SWT.NULL);
		Point size = inst.getSize();
		shell.layout();
		shell.setLayout(new FillLayout());
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch())
				display.sleep();
	public NewComposite(org.eclipse.swt.widgets.Composite parent, int style) {
		super(parent, style);
		initGUI();
	private void initGUI() {
		try {
			GridLayout thisLayout = new GridLayout();
			thisLayout.makeColumnsEqualWidth = true;
			thisLayout.numColumns = 2;
			this.setLayout(thisLayout);
				text1 = new Text(this, SWT.MULTI | SWT.WRAP | SWT.H_SCROLL
						| SWT.V_SCROLL | SWT.BORDER);
				GridData text1LData = new GridData(GridData.FILL_BOTH);
				text1.setLayoutData(text1LData);
				text1.setText("text1");
				text2 = new Text(this, SWT.MULTI | SWT.WRAP | SWT.H_SCROLL
				text2.setText("text2");
				GridData text2LData = new GridData(GridData.FILL_BOTH);
				text2.setLayoutData(text2LData);
			text1.getDisplay().asyncExec(new Runnable(){
				public void run() {
					try {
						setText();
					} catch (FileNotFoundException e) {
						e.printStackTrace();
					} catch (IOException e) {
			this.layout();
			pack();
		} catch (Exception e) {
	private void setText() throws FileNotFoundException, IOException {
		BufferedReader rd = new BufferedReader(new FileReader(new File(
				"c:\\spy.log")));
		text1.setText("");
		String line = null;
		try {
			do {
				line = rd.readLine();
				if (line != null) {
					text1.append(line);
					text1.getDisplay().readAndDispatch();
				text1.append(Text.DELIMITER);
			} while (line != null);
		} finally {
			rd.close();
give a large file to the reader instead of spy.log
you can modify this code and instead of using asyncExec for settext method you can use a UIJob in you RCP application...
or
IWorbenchWindow.run(boolean fork, boolean cancelable, IRunnableWithProgress runnable)
Previous Topic:swt browser.execute(javascript) problem
Next Topic:Being notified when other shell is being closed
Current Time: Sun Jul 20 11:07:36 EDT 2025
Powered by FUDForum. Page generated in 0.03888 seconds
