Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Being notified when other shell is being closed
Being notified when other shell is being closed [message #554393] Sun, 22 August 2010 15:19 Go to next message
I have written a test application where I want to know when the second shell is being closed.
The application starts with MainShell from where I can open SecondShell. Is there any way that I from MainShell can be notified when SecondShell is being closed?
Code from the file MainShell.java:
package swtshelltest;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
public class MainShell extends Shell
    Button buttonOpen = new Button(this, SWT.NONE);
    public static void main(String[] args)
        MainShell main = new MainShell();
    MainShell()
        super(Display.getDefault(), SWT.CLOSE);
        this.setText("MainShell");
        this.setBounds(100, 100, 200, 200);
        buttonOpen.setText("Open");
        buttonOpen.setLocation(10, 10);
        buttonOpen.pack();
        buttonOpen.addSelectionListener(openSecondShell);
        this.open();
        while (!this.isDisposed())
            if (!Display.getDefault().readAndDispatch())
                Display.getDefault().sleep();
    protected void checkSubclass()
    //funktion som körs när man klickar på knappen som startar resultatvisningen
    SelectionListener openSecondShell = new SelectionListener()
        public void widgetSelected(SelectionEvent event)
            SecondShell secondShell = new SecondShell();
        public void widgetDefaultSelected(SelectionEvent event)
Code from the file SecondShell.java:
public class SecondShell extends Shell
    SecondShell()
        this.setText("SecondShell");
        this.setBounds(400, 100, 100, 100);
        this.open();
Re: Being notified when other shell is being closed [message #554421 is a reply to message #554393] Mon, 23 August 2010 01:38 Go to previous messageGo to next message
You can add the ShellListener to your shell as shown here:
secondShell.addShellListener(new ShellAdapter() {
       public void shellClosed(ShellEvent e) {
            System.out.println("second shell closed");
In general, when you want to be notified about the state changes on the Shell (such as shell closed, shell activated/deactivated, shell iconified/deiconified) you can use the ShellListener.
HTH,
Re: Being notified when other shell is being closed [message #555168 is a reply to message #554421] Wed, 25 August 2010 12:55 Go to previous message
Ok, it was that easy.
Thanks!!!
Lakshmi Shanmugam wrote on Mon, 23 August 2010 07:38
HTH,
Previous Topic:Forcr UI update
Next Topic:Use of Display.addFilter() in practice
Current Time: Sat Jul 19 07:43:06 EDT 2025
Powered by FUDForum. Page generated in 0.07274 seconds
