Home » Language IDEs » AspectJ » Differences between java compiler and aspectJ compiler
Differences between java compiler and aspectJ compiler [message #553767] Wed, 18 August 2010 14:31 Go to next message
I have an aspectJ-enabled project, which runs properly from the IDE. However, when I try to export the project (in eclipse File->Export->Eclipse product with AspectJ support), I get errors, such as "failure[-1] running ajc" and "compile error".
I have discovered that I get the "failure[-1] running ajc" error when any plug-in in my project has a .jar on the build path that is not also on the class path. I get the "compile error" message when I have a plug-in that has multiple dependencies on another project, each with different versions. I don't get these errors when using the normal export (from eclipse, File->Export->Eclipse product) or when running from the IDE.
I'm using Eclipse 3.5.2 and AJDT 2.1.0.
Why do I get these errors ONLY when I try to export with aspectJ support? Are there settings that the aspectJ compiler uses that the normal java compiler doesn't? Is there any way I can fix this without having to change all of my plug-ins?
Re: Differences between java compiler and aspectJ compiler [message #553803 is a reply to message #553767] Wed, 18 August 2010 18:05 Go to previous messageGo to next message
I would recommend that you upgrade to Eclipse 3.6 and use the new AJDT-PDE integration. It has been completely reworked.
For details on the changes, please see:
http://contraptionsforprogramming.blogspot.com/2010/03/ajdt- pde-builds-redux.html
Your plugin project must contain at least one .java file for this to work.
Re: Differences between java compiler and aspectJ compiler [message #601215 is a reply to message #553767] Wed, 18 August 2010 18:05 Go to previous messageGo to next message
Re: Differences between java compiler and aspectJ compiler [message #631028 is a reply to message #601215] Tue, 05 October 2010 17:18 Go to previous messageGo to next message
Thanks for this info, I installed the upgrade and it worked fine =)
Re: Differences between java compiler and aspectJ compiler [message #631336 is a reply to message #553767] Thu, 07 October 2010 02:57 Go to previous messageGo to next message
Re: Differences between java compiler and aspectJ compiler [message #635530 is a reply to message #553767] Wed, 27 October 2010 05:07 Go to previous messageGo to next message
Thank you so much guys for this post. I will try it at home and let you know if it works.
Keep it up dude!
Re: Differences between java compiler and aspectJ compiler [message #636153 is a reply to message #553767] Fri, 29 October 2010 09:38 Go to previous message
I'd be interested to know how strictly you all stick to the aspect approach or how you deviate from it to make it "workable" in your corporate environment.
Previous Topic:Rebuild AspectJ project after eclipse restart
Next Topic:Enhanced ajdt.examples.progressmon
Current Time: Sun Jul 20 03:55:00 EDT 2025
Powered by FUDForum. Page generated in 0.09027 seconds
